vtec silinoid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inzane »</TD></TR><TR><TD CLASS="quote">how can u tell if ur vtec silinoid is going bad</TD></TR></TABLE>
- No VTEC
- Oil leakage
- Throwing Code
- VTEC engagement probems/ in and out of VTEC
more then likely its not going "bad" but possibly u have a bad seal casuing loss of pressure or oil?
- No VTEC
- Oil leakage
- Throwing Code
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kgs-R »</TD></TR><TR><TD CLASS="quote">Try taking it off the head, take it apart and clean it. Do a search on vtec solenoid.</TD></TR></TABLE>
and change your 2 spool filters, they're like $20 each. do it during an oil change.
r u thrownig a code??? if u are in the early 20s for blinks on your ecu or dash check engine light try cleaning it 1st. Its 3 bolts ..... unplug it ..... spray out the silinoid w/ carb cleaner or brake parts cleaner well.... let stand for a minute then plug bolt and play.. unplug your battery and restart car should work.....
