vtec problems...please help me out
Old Oct 23, 2005 | 11:29 AM
greddy13's Avatar
Default vtec problems...please help me out
ok i have a stock 2000 integra gsr with an intake on it....awhile ago the vtec was commin in at the right time and now its comming in at 6k!....does enyone no what the problem could be or what i might need to get to fix it...
Old Oct 23, 2005 | 12:07 PM
Lauj87's Avatar
thats not your vtec engagement at 6k rpms. A stock Gs R vtec engages at 4400 rpms what your hearing is the IAB opening up at 5750 rpms (AKA secondaries) if your not hearing the secondaries the first thing you should do is check your OIL level if its too low then vtec won't engage. if its just your secondaries then check vacume lines..i had a leak on mine a while back and it wasnt opening either.
Old Oct 23, 2005 | 01:41 PM
BOOSTED_JDM_DB8's Avatar
Default Re: (Lauj87)
i have the same problem, i have a vtec controller and i set it @ 5000rpm i dont feel the hard pull from the vtec untill secondaries hit. i check the oil level its at the second hole on the dip stick and i dont see any leaks from any vacum lines. what should be the problem?
Old Oct 23, 2005 | 01:46 PM
zeroz's Avatar
Default Re: (integraXgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXgsr &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem, i have a vtec controller and i set it @ 5000rpm i dont feel the hard pull from the vtec untill secondaries hit. i check the oil level its at the second hole on the dip stick and i dont see any leaks from any vacum lines. what should be the problem?</TD></TR></TABLE>
in a gsr you won't really feel vtec, secondaries is what pulls in a gsr
Old Oct 23, 2005 | 06:47 PM
greddy13's Avatar
Default Re: vtec problems...please help me out (greddy13)
before i could hear it come in at 5k or w/e and now if not that then somthin else is commin in at 6k instead....so what do i need to do exactly?...(thanks so much for the help guys)
Old Oct 23, 2005 | 06:48 PM
greddy13's Avatar
and my oil is fine..
Old Oct 23, 2005 | 06:52 PM
zeroz's Avatar
yeah its just you can't hear some things when u have some things on like me for example
got exhaust with cold air could not hear secondaires but vtec howls and then i swap back to short ram for winter and now i can't hear vtec but secondaries scream
Old Oct 23, 2005 | 06:58 PM
Yambor's Avatar
NOOBVILLE...
your vtec is still "working" chill out....like everyone else said..
Old Oct 23, 2005 | 06:59 PM
greddy13's Avatar
it just started to happen..with or without the intake on there its the same it started before i put the intake on there i think
Old Oct 23, 2005 | 07:33 PM
zeroz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddy13 &raquo;</TD></TR><TR><TD CLASS="quote">it just started to happen..with or without the intake on there its the same it started before i put the intake on there i think</TD></TR></TABLE>
well think hard now and remember it
Old Oct 23, 2005 | 08:27 PM
greddy13's Avatar
yea it started before lol
Old Oct 24, 2005 | 02:23 AM
ben_eg6's Avatar
[QUOTE=Lauj87]thats not your vtec engagement at 6k rpms. A stock Gs R vtec engages at 4400 rpms what your hearing is the IAB opening up at 5750 rpms (AKA secondaries) if your not hearing the secondaries the first thing you should do is check your OIL level if its too low then vtec won't engage. if its just your secondaries then check vacume lines..i had a leak on mine a while back and it wasnt opening either.[/QUOT]
I thought vtec is not kick in until 4700-4800 RPM ?
I don't know what might be a problem, but you can check your vtec solenoid to see if it work. I would check the Oil level first lol. I'm sure this has been coverd many many times.
Anyways, here is how you do it.
Engine off, Disconnect the Vtec solenoid plug, find a wire and jump it to the POSITIVE TERMINAL lead of the battery. You should hear a sticking sound, if not your vtec solenoid is bad.
********Remember to reset the ecu or it'll throw a code************
Old Oct 24, 2005 | 10:40 AM
greddy13's Avatar
alright thanks guys!....ive learned somhtin new
h2b-ubeezy
12
Jun 5, 2008 08:11 AM
Em1_coupe
23
Feb 20, 2008 07:11 PM
210jdmgsr
Jul 30, 2007 06:27 PM
Sicarius82
Jul 25, 2006 02:42 PM
BlckSI
Aug 29, 2003 06:48 PM
