Vtec problem :(
I have a 95 Integra GSR with very high compression--13:1 and i am running mobil 5W30 oil. I have a unchipped P28 ecu and have about 2500 miles on the motor now. However i have been getting a good vtec cross over out of it ever since i was done breaking my motor in. All of a sudden im not getting any vtec at all. no check engine lights, oil level is good, wiring is good and un cut. I cant not seem to figure out why im not getting vtec and the only thing i can think of is a bad TPS or that my TPS is not getting good readings. I think this because if i beat on the car with vtec or not the idle surges, however if i do not beat on it the idle is fine. Can anyone help me out with this one? thanks
Make sure your engine temp is not to high! To high engine temp the VTEC will not work. 13:1 comp will increase you temp! make sure you rad is OK. If it is to high and your rad is OK check your thermosat.
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The HamsterBall »</TD></TR><TR><TD CLASS="quote">its ok to use 5w30 on such a high compression engine ? i mean 13:1 is kinda crazy.</TD></TR></TABLE>
So is a stock p28. That's a civic ECU right? Runs waaay lean? ...with 13.1 compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">13:1 wowow someone has been trying to play sleeper...</TD></TR></TABLE>
SHHH
and with that ECU i am running really really lean.....i got a VAFC to change that but its not hooked up and im in the search for an OBD1 P72---GSR ecu
And the radiator is brand new from a 99 Integra so thats an aluminum one not steel.....
SHHH
1JDMDOMINICAN
Mar 20, 2007 02:03 PM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
