vtec not working pls help
Old Apr 1, 2009 | 07:19 PM
littlevtec's Avatar
Default vtec not working pls help
i have a lsvtec with a b16 head... i have searched and have tryed everything that has been suggested. problem is i do have proper oil pressure at the back of the head provided from my -4 feed line. But with the gauge at the front of the head. there is none. vtec solinoid works with 12v. anybody can think of anything else that i haven't tryed... kinda stumped. i also found a thread on here about a pin that is located in the center of the head that locks the rockers in, but that is there so thats not the problem.
Old Apr 4, 2009 | 07:34 AM
bada9's Avatar
Default Re: vtec not working pls help
clean out the vtec solenoid, contaminents get into the oil then plug them up from time to time
Old Apr 4, 2009 | 08:14 AM
littlevtec's Avatar
i did that already and its all clean... i was told by a friend that maybe the feed line is too small... so i'm changing it to a -6 and going to see if that helps. i'll let u guys know. thanks
Old Apr 4, 2009 | 08:50 AM
sixfourkiller's Avatar
well are u still using your stock ecu cause that could be your problem if u still are... it doesnt have mapping for the v-tech
Old Apr 4, 2009 | 01:35 PM
wegotmorrison's Avatar
Check your VTEC Fluid
Old Apr 7, 2009 | 04:48 PM
honda_civic_si's Avatar
New User
i need help on my civic with gsr swap i have no vtec i need help
Old Apr 7, 2009 | 06:33 PM
aemintgsr's Avatar
Does the engine let you rev all the way or does it stop like around 6k rpms... if it revs all the way than vtec is kickin in but you just cant hear it.
Vtec will not also kick in if you speedo is bad, engine is cold, not enough oil, or dont have the right ECU.
Br1gHtDc2
Aug 12, 2008 01:39 PM
B18c1turboedEK
Jun 6, 2007 10:07 AM
T3k C
Mar 19, 2007 02:22 PM
pr3B20pwr
Apr 4, 2005 03:56 PM
vaporboy12
Nov 18, 2004 11:01 PM
