vtec not working need help!!!!
Old Jun 28, 2009 | 06:16 PM
joeg_713's Avatar
Default vtec not working need help!!!!
my v-tech is not working on my pr3-3 head. i already changed my solenoid ,wired it direct and still nothing what should i do?
Old Jun 28, 2009 | 06:26 PM
ek-g6's Avatar
Default Re: v-tech not working need help!!!!
do you have any CEL?
Old Jun 28, 2009 | 06:30 PM
joeg_713's Avatar
what do you mean by cel.. sorry?
Old Jun 28, 2009 | 06:34 PM
ek-g6's Avatar
CHECK ENGINE LIGHT (CEL) heres a how to:
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Old Jun 28, 2009 | 06:41 PM
joeg_713's Avatar
cool im going to try that but something tells me is something else.. but its worth a try since im tired of not finding the problem.
Old Jun 28, 2009 | 06:43 PM
joeg_713's Avatar
plus i dont think i ai have a cel but it might have been taken off since i bought the car like that!
Old Jun 28, 2009 | 06:44 PM
ek-g6's Avatar
reasons for no VTEC operation include low engine oil level, VTEC solenoid not opening or the screen behind it is restricted, an engine that has low oil pressure, or an oil pressure leak to the rocker arm assembly. In some cases, when engine work is performed, a missing or damaged O-ring can cause incorrect oil pressure to the VTEC system.
Old Jun 28, 2009 | 06:57 PM
joeg_713's Avatar
i guess i might have to rebuild my head if im going to take it off. i wonder how much does it run for..
joeg_713's Avatar
THANX THO
Old Jun 28, 2009 | 07:00 PM
ek-g6's Avatar
I dont think you need to take off the head to find out why vtec isnt working? unless the head itself isnt good anymore.
Old Jun 29, 2009 | 04:52 PM
94 ls-r's Avatar
Default Re: vtec not working need help!!!!
Hook a gauge to the head at the front by the solenoid. There shold be a plug ya can pull out. Then you can hardwire the selonoid to keep it open to monitor pressure. Dont leave it that way for to long. Is the oil pressure safety swith hooked up.
Old Jun 29, 2009 | 08:55 PM
joeg_713's Avatar
yeah everything is hooked up,oil is good and wired direct but thats a good idea..
Old Jun 30, 2009 | 10:42 AM
shadohc's Avatar
If your v-tech is not working you should get a new phone or call your service provider and get it fixed lol
Old Jun 30, 2009 | 11:07 AM
1992blueGSR's Avatar
wow
GTFO!!!
Old Jun 30, 2009 | 06:55 PM
1991b20bteg's Avatar
what kind of ECU are you using? on what kinda car?
Old Jul 1, 2009 | 06:29 AM
djtsmith007's Avatar
re charge your phone
Old Jul 1, 2009 | 06:35 AM
all joking aside, what makes you think its not working? Most people write of no "pop" or huge acceleration when vtec kicks in. Not really what it actually does. If you know for sure its not, and no work as been done on the head and assuming the engine is older its probably burning oil and you might just be low. Sometimes its the simple things.
JaysonDC2
Apr 9, 2010 04:49 PM
mister2racer
Jun 26, 2005 07:13 PM
Worangejuice
Nov 15, 2003 06:36 PM
311
Oct 23, 2002 08:20 AM
