VTEC Noob
Old Jun 8, 2006 | 04:05 PM
SlamminS85's Avatar
Default VTEC Noob
What are teh reasons for the VTEC light to come on?
I am under the assumption it doesnt light up during normal operatin in or out of VTEC
Old Jun 8, 2006 | 04:07 PM
Lan's Avatar
Lan
Default Re: VTEC Noob (SlamminS85)
What does the car drive like? Have you felt a loss of power when vtec engages? Pull your cylinoid off and check the filter inside for debris if you are.
Old Jun 8, 2006 | 04:09 PM
SlamminS85's Avatar
Default Re: VTEC Noob (Lan)
the light doesnt come on, i was test driving a potential buy, the car drives well, it looks like there is a small oil leak around the dizzy (lower than the dizzy and more toward the front of the car)
Old Jun 8, 2006 | 04:10 PM
SlamminS85's Avatar
in response to how it drives, i like it, its a manual, never driven a GSR before so i dont know, all i have now is my Automatic LS
Old Jun 8, 2006 | 04:11 PM
Lan's Avatar
Lan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">the light doesnt come on, i was test driving a potential buy, the car drives well, it looks like there is a small oil leak around the dizzy (lower than the dizzy and more toward the front of the car)</TD></TR></TABLE>
The oil leak you saw was most likely coming from the vtec cylinoid, gasket could have to be replaced and the car's light woul most likely go off unless there was another problem.
Old Jun 8, 2006 | 04:14 PM
SlamminS85's Avatar
im really just asking, what causes the VTEC light to turn on?
During normal operation and you cross over into VTEC... the light stays off correct?
Also about the VTEC colinoid... i dont have to remove the head to replace something arond there do I... it runs fine now, smells of burning oil only right when you start it up, doesnt smoke, sounds beautiful, rides ultra smooth
Old Jun 8, 2006 | 04:16 PM
Lan's Avatar
Lan
The leak in the cylinoid will cause a light to come on most likely. The cylinoid does not require you to take the head off. It is only a couple of bolts and should take 30 seconds to take off.
Old Jun 8, 2006 | 04:36 PM
SlamminS85's Avatar
sweetness, that is exactly what i was wondering
teggy_617
May 10, 2008 12:31 PM
Pr-Type-R
Apr 20, 2008 05:09 PM
GTEC913
Mar 11, 2006 03:46 AM
superchargedex
Apr 14, 2005 12:14 PM
hotdoggies
Apr 9, 2005 10:22 PM
