vtec issues
Old Oct 22, 2008 | 07:21 PM
D_koschak's Avatar
Default vtec issues
so i have a 96 turbo teg i started having vtec problems with it a few months ago it went completely out so i bought a new distributor cause i was having problems with that didnt help vtec at all so i went out and bought a brand new p28 now the vtec kicks in at 6000 and cuts back out at 6800 anyone know what the deal is, i already cleaned the filter on it and checked the oil level any info would be helpful thanks dave
Old Oct 25, 2008 | 11:30 AM
D_koschak's Avatar
Default Re: vtec issues (D_koschak)
so no one on this forum knows anything about vtec
Old Oct 25, 2008 | 12:26 PM
luv2boost's Avatar
has the engine been swapped to ls vtec?
Old Oct 25, 2008 | 07:19 PM
civic_teg's Avatar
New User
have you checked the pins in the computer plugs if that makes any since and check the metal piece inside the vtec plug on the sylinoid
Old Oct 26, 2008 | 12:04 AM
D_koschak's Avatar
no the motor is stock gsr with forged intenals, i have probed every wire perfect continuity even ran new wires and still nothing
Old Oct 26, 2008 | 12:14 PM
cdntegintx's Avatar
Any check engine lights?
Also if you have a turbo, I'm assuming you have an oil pressure gauge, whats the pressure at?
Old Oct 26, 2008 | 07:10 PM
D_koschak's Avatar
Default Re: (cdntegintx)
yeah the check engine light came on for code 21, yes i do have one and at idle i have 75 and at about 4000 rpms im at 100 so its enough for vtec to work im wondering if it is inside the head thats messed up
Old Oct 26, 2008 | 07:14 PM
LSracing94's Avatar
Default Re: (D_koschak)
what software are you running..youre obviously tuned right?
Old Oct 27, 2008 | 07:32 AM
D_koschak's Avatar
Default Re: (LSracing94)
chrome software and i was tuned by the guy that tuned the fastest street s2000 so i know he isnt a bunk tuner
Old Oct 27, 2008 | 08:44 AM
letsdrive's Avatar
so youre car is tuned and you go out and buy a new UNTUNED p28 to fix your vtec problem in your TURBO teg ? not very smart. you need to go do some reading about vtec then you can start troubleshooting again. try SEARCHing here or on
team-integra.net<---better info than HT in my opinion.
Old Oct 27, 2008 | 09:00 AM
HONDRETTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_koschak &raquo;</TD></TR><TR><TD CLASS="quote">yeah the check engine light came on for code 21, yes i do have one and at idle i have 75 and at about 4000 rpms im at 100 so its enough for vtec to work im wondering if it is inside the head thats messed up </TD></TR></TABLE>
codes dont lie
Old Oct 27, 2008 | 01:21 PM
D_koschak's Avatar
Default Re: (letsdrive)
i was running a chipped p05 converted to a p28 so the only thing i had to do was remove the chip from the one and put it in the other not very hard to think about and its not very dumb to do, its perfectly safe, similar ecu just one is converted
Old Oct 27, 2008 | 01:26 PM
D_koschak's Avatar
Default Re: (HONDRETTI)
i know the codes dont lie but i have switched with 4 different ones and 2 that i actually know that work and 2 i got from the junk yard, when i hooked up constant power to them they work fine but car doesnt run good like that cause of the tuning reason
Old Oct 27, 2008 | 02:15 PM
Rajin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_koschak &raquo;</TD></TR><TR><TD CLASS="quote">i know the codes dont lie but i have switched with 4 different ones and 2 that i actually know that work and 2 i got from the junk yard, when i hooked up constant power to them they work fine but car doesnt run good like that cause of the tuning reason</TD></TR></TABLE>
I know this, you do lack a mastery of the English language.
Team-integra.
Look there.
BlueSmartEm1
13
Jul 3, 2011 09:26 PM
DougNuts
Jan 19, 2008 01:16 PM
mtg4gen
Apr 9, 2007 09:02 PM
J's GS-R
Feb 23, 2006 06:14 PM
thangbui
Oct 23, 2005 08:05 AM
