VTEC IS DEAD??
Old Nov 29, 2001 | 05:55 PM
racinghart 00 gs-R's Avatar
Default VTEC IS DEAD??
Hey,
I have a 00 Gs-r with 39000 miles and it hasent had the valves adjusted yet, it has the little tapping noise from the motor and i assume that means time for a tune up, but not my vtec doesnt kick in, could this be a result of the vavles being messed up? also, my shop said i need a cap and rotor also, this sound right? Thanks
JJ
Old Nov 29, 2001 | 06:34 PM
Chris's Avatar
Default Re: VTEC IS DEAD?? (racinghart 00 gs-R)
check your oil level, let the car warm up, and lastly..Floor it.
Old Nov 29, 2001 | 06:48 PM
Default Re: VTEC IS DEAD?? (Chris)
Just changed the oild today, it is still messed up, any ideas?
Old Nov 29, 2001 | 06:51 PM
gsr camel's Avatar
make sure the wire to the vtec solonoid is not frayed or damaged and check all fuses and once again FLOOR IT. hehe
Twanks
Old Nov 29, 2001 | 07:55 PM
LostGsr's Avatar
if your vtec is not engaging, it should trigger a CEL.
Old Nov 29, 2001 | 09:29 PM
B00ST2nR's Avatar
Default Re: VTEC IS DEAD?? (LostGsr)
2000 GS-R with 39,000 miles? wow. That's alot. I only have 3,700 miles on it. I barely drive my GS-R. Its my weekend car. I drive my Nissan Truck mostly...
Check the wires and get your adjustments done. It should be ok...
Old Nov 29, 2001 | 09:36 PM
Chris's Avatar
Default Re: VTEC IS DEAD?? (GS-Racer)
2000 with 39K...wait, my 2000 has 26K
Old Nov 30, 2001 | 04:21 AM
APEXKING's Avatar
New User
I hope you have done an oil change in that 39,000 miles.That is also alot of miles,i have a 99 GSR and it is just about to hit 30,000
Old Nov 30, 2001 | 05:55 AM
Dirty GS-R's Avatar
New User
That's not true. I had a problem with my vtec not engaging a while back and I never got a CEL.
Old Nov 30, 2001 | 06:19 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: VTEC IS DEAD?? (APEXKING)
my 97 just rolled 111,200 miles this morning on my 30 mile one-way commute to work! bought the car with 40,309 in june of 99!
Old Nov 30, 2001 | 06:59 AM
integra2000's Avatar
New User
Default Re: VTEC IS DEAD?? (FuknGSR)
my 2000 just hit 47k.
Old Nov 30, 2001 | 07:06 AM
gsrpowered95's Avatar
New User
geez you are some drivin mafaka's I got a 95 gsr with 64,xxx on it right now.. was my daily driver but i moved into a apt 1 block away from work so i could sleep in everymorning.. but before that I had to drive 80 miles each way to work oh well i drive when I can I love my leather :D
Old Nov 30, 2001 | 07:58 AM
2fastGSR's Avatar
King of the One Liners
Default Re: VTEC IS DEAD?? (gsrpowered95)
SOmetimes when I would change the oil in my 94 GSR the VTEC would not engage all the time for a day or two, then it would go back to normal of working perfectly. Just drive it around normally for a bit. Don't know why this happens, but just letting you know happens to others too.
Old Nov 30, 2001 | 10:04 AM
Frosty_spl's Avatar
Default Re: VTEC IS DEAD?? (2fastGSR)
my vtec didnt work so i bought a new head. there was something inside the head blocking the oil passages, causing it not to engage.
Old Nov 30, 2001 | 10:48 AM
KraZyCHOWMEIN's Avatar
Default Re: VTEC IS DEAD?? (Frosty_siR)
the mechanic was talkin about the distributor cap and rotor... cost for both is around 30 buxs at the dealership...
you can also take off the vtec solinoid and check the metal screen behind it.. if this is plugged up with junk.. then yes clean it out and thas probably why ur shiet wasnt workin.
also when did it stop workin, is ur car stock and u just cant feel it, do u know what RPM's the vtec and the secondary butterflys open up at, and is ur car idling high all the time meaning above 1000 rpms....ur car may be stuck in limp mode.. meaning no vtec.........
Old Nov 30, 2001 | 02:07 PM
AzN_Flava's Avatar
hehe i have a 94 with 58250 miles...
ummm yah GO FLOOR IT.. i dunno...
Old Nov 30, 2001 | 02:11 PM
SuperMan19's Avatar
New User
Default Re: VTEC IS DEAD?? (AzN_Flava)
my 97 has 41k!!!
Old Nov 30, 2001 | 02:22 PM
gsr stuie's Avatar
Default Re: VTEC IS DEAD?? (MyKarsNameIsMichelle)
Vtec works on oil presure so check and see if there's oil, secondly check and see if the oil presure sensor is working.
speedking
Jul 3, 2008 09:37 AM
IntegraTypeR777
Jun 22, 2007 07:21 PM
2slo2ugly
Apr 7, 2005 01:35 PM
cw98typer
Oct 26, 2002 12:41 PM
92GSR
Apr 28, 2002 10:06 PM
