Vtec conversion kits??????
Guest
Posts: n/a
I'm new to the world of integra's i just bought an 01 ls i want to convert it to vtec should I use a b16 head? and does anyone know anything about those vtec conversion kits
The kit includes:
1. Golden Eagle Vtec Conversion Sandwich Plate with a -6AN fitting for the plate and head.
2. -6AN steel braided teflon hose for oil supply
3. Golden Eagle Vtec Conversion Dowels for proper alignment of the head and block without machining
4. 1/8 NPT tap and plug for the oil port in the head
5. Golden Eagle worked factory head gasket with any bore size and dowel holes opened for any application
Good no good? anything please help.
The kit includes:
going LS/VTEC? use the B16 head... get it ported and polish! just dont be dumb like those stupid ******s up in college point, queens new york... that dunno jack **** about LS/VTEC.... they got a LS motor with a GSR HEAD which made their car slower than a regular stock LS... dunno what they were doing to their cars... but i've met a few of them...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvs gsr »</TD></TR><TR><TD CLASS="quote">going LS/VTEC? use the B16 head... get it ported and polish! just dont be dumb like those stupid ******s up in college point, queens new york... that dunno jack **** about LS/VTEC.... they got a LS motor with a GSR HEAD which made their car slower than a regular stock LS... dunno what they were doing to their cars... but i've met a few of them...</TD></TR></TABLE>
A GSR head and a B16 head flow pretty much the same as one another, in fact the GSR head has straighter intake ports and offers higher compression than the B16 head. It's all a matter of building the motor correctly. Ideally, you would have the rotating assembly balanced and use higher compression pistons. Also a crankshaft girdle isn't a bad idea. The Golden Eagle kit makes it a relatively painless process to put the head on correctly assuming you have some experience in the area. But the general rule of thumb surrounding the head choice is a GSR head for anything 81mm, a B16/Type R head for anything bigger.
authentic plusONErandy
Jan 11, 2006 08:52 PM
