valve spring
Old Apr 21, 2004 | 09:24 PM
newBcrxer's Avatar
Default valve spring
i beleive that one of my valve spring is no good anymore cuz i hear this dump dump sound from my engine. i was wondering if there was any performance valve springs or just stock or itr springs. also how much should the spring be worth?
Old Apr 21, 2004 | 10:58 PM
Slain's Avatar
i would do a compression test and leakdown test if you are hearing that noise..... itr springs arent too expensive. i would be a little worried hearing that noise...
Old Apr 22, 2004 | 12:15 AM
neo1z's Avatar
Default Re: (Slain)
I am not sure how you immediately derive valvespring from a dump dump noise - you should take a sound clip from you car so we can hear it...dump dump doesnt help lol.
I would do a Comp test as Slain mentioned though for sure.
Old Apr 22, 2004 | 05:55 AM
AnotherGSR's Avatar
Could be a lost motion assembly too, dose it make this noise when idling?
How many miles on the car??
Old Apr 22, 2004 | 08:55 AM
newBcrxer's Avatar
Default Re: (AnotherGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnotherGSR &raquo;</TD></TR><TR><TD CLASS="quote">Could be a lost motion assembly too, dose it make this noise when idling?
How many miles on the car??</TD></TR></TABLE>
while its idling is when it makes that sound .. about 45k on the motor (b18c1motor)
Old May 5, 2004 | 08:30 AM
AnotherGSR's Avatar
is your idle rough?
Old May 5, 2004 | 05:07 PM
newBcrxer's Avatar
ohh had the prob fix ..it wasnt the spring .. it was just a spark plugs that was loose in the engine .. so just tighted it and the nosie went away. thanks anyways guys
Black Ack
Dec 19, 2006 04:48 PM
pbinteg99
Jun 19, 2003 11:29 AM
pbinteg99
Jun 18, 2003 04:13 PM
