valve clicking in engine
Old May 8, 2006 | 08:59 PM
sixtodc2's Avatar
Default valve clicking in engine
well i got an 01 ls integra ..my engine is making some kind of knocking sound when i rev or no rev it clicks when its on idle or when i press the gas... i fix the problem once and it went away .. i got the valves retighten and its was quite for a day or two.. then i brought it to the dealer they said it was fine but my friend has the same model and mods on his car and it does not click at all.. any idea guys need help!!!
Old May 8, 2006 | 10:04 PM
themilman's Avatar
Default Re: valve clicking in engine (sixtorice)
"my engine is making some kind of knocking sound when i rev or no rev it clicks when its on idle or when i press the gas."
so what your saying is that its clicking all the time, right?
run some engine cleaner through it (local parts store $5), follow the directions, change the oil.
Old May 8, 2006 | 10:12 PM
SlammedDC2teg's Avatar
YO need a valve adjustment. My old LS did it all the time, its not bad for the engine. Its probably the valve springs.
Old May 8, 2006 | 10:29 PM
vuong916's Avatar
Default Re: valve clicking in engine (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">YO need a valve adjustment. My old LS did it all the time, its not bad for the engine. Its probably the valve springs.</TD></TR></TABLE>
what he said valve adjustment and oil change
Old May 9, 2006 | 02:41 PM
themilman's Avatar
this is a 2001 LS, not an old LS. My 91 ticks, so does everybodies, normal, but a 2001? I doubt his valves need adjusting. You can always check the valve lash.............$4 tool, remove valve cover, follow instructions in manual or found online, prob take you 60mins first time.
Old May 9, 2006 | 02:45 PM
Uncle Willie's Avatar
Default Re: (themilman)
My 94 gsr has a ticking noise also. I already did a valve adjustment but it didnt do ****. Now im gonna try and replace LMA's. (which i dont think you have)
Old May 9, 2006 | 02:55 PM
cm zak's Avatar
year doesnt really matter, more so how you drive the car, it could be valves need adjustment.
Old May 9, 2006 | 03:55 PM
Default Re: (cm zak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">year doesnt really matter, more so how you drive the car, it could be valves need adjustment.</TD></TR></TABLE>
did you read original post.
Old May 9, 2006 | 05:45 PM
old_school_dohcvtec's Avatar
well our engines are notorious for loud injectors. it could be that?
Old May 9, 2006 | 06:56 PM
Black Widow g2's Avatar
Default Re: valve clicking in engine (NZGSR)
'loud injectors'
wow... you're a winner. honda's are however notorious for valve click. they need to be adjusted with every oil change or there about if you have a vtec motor. trust me... a bit of click is alright, but you need to make sure the clearance is up to par etc.
have someone adjust the valves and make sure the valves are clearanced properly.
Old May 9, 2006 | 09:58 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
wat are LMA's
Old May 9, 2006 | 10:31 PM
HOsNiDA's Avatar
Default Re: valve clicking in engine (themilman)
Dont do the parts cleaner. BAD IDEA NUMBER ONE. I got my head ported and polished. Weak later tried some motor flush. Then changed my oil to go to races. BAD IDEA. Ruined the valve seals
Old May 10, 2006 | 03:04 PM
Default Re: valve clicking in engine (Black Widow g2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Widow g2 &raquo;</TD></TR><TR><TD CLASS="quote">'loud injectors'
have someone adjust the valves and make sure the valves are clearanced properly.</TD></TR></TABLE>
valves adjusted every oil change?..... i dont think the valves go out of spec that quickly
Old May 10, 2006 | 10:23 PM
themilman's Avatar
Default Re: valve clicking in engine (HOsNiDA)
If you put motor flush in your engine and it ruined your valve seals you did something wrong. Sheesh, its $4 at the parts store, it can't be that strong. What did you do, leave it in your car? Its called "Flush" for a reason, your supposed to run it and change your oil right then, not a week later. Regardless of what you did or didn't do, MOTOR FLUSH could not, and did not, ruin your seals. Perhaps it was the racing???
Brembomaster
May 26, 2019 07:51 PM
wade
Mar 18, 2009 01:30 AM
Iomega01
Aug 9, 2005 08:08 AM
eswaroop
Mar 26, 2004 03:44 PM
Comptech98GSR
Aug 27, 2002 08:55 PM
