vafc version 2?
Old Aug 4, 2003 | 10:36 AM
genetsang's Avatar
Default vafc version 2?
is it better than Apex's first version.. or is it basically the same...
Old Aug 4, 2003 | 12:46 PM
genetsang's Avatar
Default Re: vafc version 2? (genetsang)
Old Aug 4, 2003 | 12:55 PM
riceball777's Avatar
i think the version 2 is for i-vtec
i may be wrong though
Old Aug 4, 2003 | 12:58 PM
genetsang's Avatar
Default Re: vafc version 2? (riceball777)
on the options auto site... it says
" DIGITAL VTEC AFC II
Completely redesigned user interface for easier navigation.
Integrated fuel/VTEC control (including i-VTEC).
Control VTEC engagement point from 3000-7000 RPM (100 RPM Increments).
Red LED light indicated low-high cam switch over.
VTEC match/unmatch function compensates for fuel differences between modified VTEC engagement point and ECU engagement point.
24 fuel adjustment points (12 high cam, 12 low cam).
Fuel curve is adjustable in 200 RPM increments for fine tuning.
Monitor 1-VTEC variable intake cam timing in real time.
Integrated knocking monitor (for vehicles equipped with factory knock sensor).
Password protection.
Slimmer case design fro ease of installation."
To me. it basically sounds the same as their previous Vafc...
Old Aug 4, 2003 | 12:59 PM
genetsang's Avatar
just want to know who has experienced with Apexi's redesign and performance. thanks
Old Aug 4, 2003 | 01:05 PM
Kidd_Stylez's Avatar
besides all that you have already mentioned, i think it also lets you have 2 different settings for the same car. For instance a track setting where you might be running higher boost and a higher grade octane (116) and then you street setting for getting to the track and leaving the track. You can toggle between the two settings at the push of a button and your paramaters will be changed.
Old Aug 4, 2003 | 06:08 PM
genetsang's Avatar
Default Re: vafc version 2? (Kidd_Stylez)
hmmm is that you think or.. is that what apexi says about the version 2?
BryanPendleton
Jul 6, 2004 08:41 AM
austrian type-R
Jul 31, 2002 05:57 AM
seanb18c1
Feb 27, 2002 01:36 PM
Wet Nudl
Feb 25, 2002 01:46 PM
EGtoR
Jan 19, 2002 11:27 PM
