VAFC question!!!
Old May 10, 2004 | 01:24 PM
B00ST2nR's Avatar
Default VAFC question!!!
I went in for a smog test today. I passed the Function Check and Emissions Test, but failed in the Visual Inspection.
I have to fix 2 things. A Fuel leak in the Fuel Rail, and the VAFC.
I ordered a new fuel rail, so that should be comming soon. The problem is the VAFC.
Now my question is... if I unplug the VAFC from my ECU, will it save the settings it has right now? Or will it go back to the initial settings??
Old May 10, 2004 | 01:29 PM
genetsang's Avatar
Default Re: VAFC question!!! (Skunk2nR)
it will be saved.. if you are skeptical about it. jot down all the settings and save it somewhere. and reenter it when are done with the inspection.
*only if you think the settings have been changed or altered*
Old May 10, 2004 | 08:46 PM
B00ST2nR's Avatar
Default Re: VAFC question!!! (genetsang)
anyone else? Someone told me once you unplug the VAFC it goes back to initial settings.
Someone know FOR SURE?
Old May 10, 2004 | 10:09 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">anyone else? Someone told me once you unplug the VAFC it goes back to initial settings.
If you unplug the AFC from the harness (NOT the ECU), the settings will be saved. Don't worry. I did it all the time when I parked somewhere. I took it with me or locked it in the trunk so it didn't attract any theives.
Unplug it from the middle and hide the rest of the wire from your ECU and you should be fine. Unfortunately, I don't know how your car will run without the AFC and your emissions numbers might be even worse.
Anyway to answer your question, your AFC WILL NOT lose the settings if you unplug it.
1999all_motoR_teg
13
Jan 12, 2005 09:53 AM
bpowa
10
Oct 26, 2004 11:09 PM
B00ST2nR
May 15, 2004 06:11 PM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
max
Oct 14, 2001 02:54 PM
