vafc problem...
Hey guys, I just installed my vafc yesterday and have a couple of problems that I think are related. The first one is, the vafc doesn't properly read my rpms. At idle, the vafc is about 200 rpms low, and by the time I get get up to 5000 rpms, the vafc only shows me at around 3600 rpms. When I am at 8000 rpms, the vafc shows 6000 rpms.
The second problem is, when i set my vtec point, it doesn't actually kick in until about 2000 rpms after it is supposed to. Since the vafc is way behind on my rpms, I'm thinking this is why the vtec doesn't crossover until almost redline.
Has anyone had this problem and know what I need to do? I haven't changed any settings away from default except the vtec changes. Btw, I have a 97 gsr.
[Modified by KC GSR, 8:18 AM 8/29/2002]
I'm at work so I haven't got a chance to mess with it anymore but I realized I also haven't changed the intake pressure or air correction rate settings. Default is Pr: 760 ~ 0...anyone know what it needs to be for GSR? (760 ~ 0, 760 ~ 1.0, 760 ~ 2.0)
settings correct?
6 in 6 out?
4 cly, throttle up-right?
6 in 6 out?
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i accidentally forgot to change it to 4 cly when i hit initialize, and i started my car. i heard a strange bumping, thumping sound, like a faint subwoofer was playing but from my engine bay. i got scared and realized my mistake =P
What happened was when i went through the setup before i started the car the first time, I set everything but then i didn't read the instructions correctly and I selected initialize. Obviously this reset everything back to default and so it was running in 6 cyl mode again, that was the prob. Now if I can ever figure out why the heck vtec drops out occasionally around 7000 rpm I'll be happy
[Modified by KC GSR, 12:30 PM 8/31/2002]
yea, i did the same thing when i first installed my vafc. i didn't read the manual thoroughly
. i initialized it and kept getting false readings. didn't know i was resetting my setting by doing this. i went back to the manual and figured everything out. you're not alone on this.
