Using a timing gun....
Hello:
You really do not even need to know the numbers, if you look close on your crank pulley you can see the mark you are supposed to aim for when setting the timing. Remember you need to place a jumper in a wire harness inside of the car when performing the timing check.
Thanks
Thanks
