Type R head
Old Aug 22, 2003 | 07:27 AM
pikapp440's Avatar
Default Type R head
What do you think about putting a Type R head on a GSR block. I plan on overboring the block and building the bottom for NOS, but I dont know if spending the money for a ported and polished head is worth the difference it cost between that and a Type R head. Also, is there any need to change to a Type R ecu from the gsr if i do so with the head?
Old Aug 22, 2003 | 08:07 AM
skribblah's Avatar
Default Re: Type R head (pikapp440)
just put type r cams in your GSR head. and just get your gsr head ported and polished. it is worth the differance. i have heard of people gaining upwards of 25WHP from head porting. and no dont screw with the ecu.
Old Aug 22, 2003 | 11:59 AM
BolivianDc2's Avatar
Default Re: Type R head (skribblah)
agreed, depending on where you are tho, if you can bring the head yourself to to P&P it would save you the shipping charges. Also think if you are not going to get new pistons the type R head will bump your compression down.
Old Aug 22, 2003 | 12:05 PM
Slain's Avatar
as said the itr head will lower compression a tad. Remember the itr head is only a very mild port and polish. You will need to get a vafc or your ecu chipped if you go with the itr head.
Old Aug 22, 2003 | 12:36 PM
95 Gizzer
Guest
Posts: n/a
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">as said the itr head will lower compression a tad. Remember the itr head is only a very mild port and polish. You will need to get a vafc or your ecu chipped if you go with the itr head.</TD></TR></TABLE>
and you cant really P&P the itr head
Old Aug 22, 2003 | 12:52 PM
Default Re: (95 Gizzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 Gizzer &raquo;</TD></TR><TR><TD CLASS="quote">
and you cant really P&P the itr head</TD></TR></TABLE>
yes you can, there is plenty of room for improvement on the head to make it flow better
mynameizstitch
Apr 8, 2013 07:43 PM
jdm0ua
Jan 13, 2007 09:50 AM
ASHY-ELBOW
May 16, 2003 01:04 PM
underpressure02
Dec 20, 2002 06:17 PM
