Trunk problem..
Old Jan 20, 2010 | 09:17 PM
oh_dam's Avatar
Default Trunk problem..
so i bought an integra, it don't have the lever to pull and dude lost the key.
how else am i suppose to open the trunk ? on and actualator or w.e is not working either. would like some info on how i can get it open please and thank.
Old Jan 20, 2010 | 09:56 PM
SoTexDC2's Avatar
Default Re: Trunk problem..
Been there, not fun..
Start by folding the rear seats down. Pry the rear-most plastic interior piece up to access the rod that ties the key lock cylinder and actuator together. It should manually release the latch for you.
Old Jan 20, 2010 | 10:06 PM
oh_dam's Avatar
Thanks.! i appreciate that. now i just have to figure out how ima pry it.
are you from texas.?
Old Jan 20, 2010 | 10:23 PM
SoTexDC2's Avatar
I live in Texas, yes. Not exactly close to DFW though.
You will need to remove the tie downs from the rear also. They are on the bottom in the back, I believe they are 10mm bolts. Then remove the plastic phillips headed clips from the bottom. It's also secured by more clips at the top, which you cannot access until you get the hatch open. You can pry the plastic up just enough to get to the latch, but its a really tight fit.
If all else fails, you can always cut the plastic panel away. If it comes to that, I have an extra black one I'll sell you cheap.
Old Jan 20, 2010 | 10:33 PM
SoTexDC2's Avatar
You're in luck, I found a pic.
Yellow circles are the Phillips Head fasteners.
Red circles are where the 10mm bolts are that secure the tie downs. Apparently, not all Integra's have them though. Mine does..
Old Jan 20, 2010 | 10:36 PM
oh_dam's Avatar
Thanks for the pic that help out alot.! and oh which part of texas you from? are you going to the cupcake meet this weekend if you heard of it .
Old Jan 20, 2010 | 10:41 PM
SoTexDC2's Avatar
I'm in the Austin/San Antonio area.
Yes, I've heard of it. I don't goto those meets or local events, when it comes to my car I just keep to myself. Too many thieves and vandals around now days.
Old Jan 20, 2010 | 10:54 PM
oh_dam's Avatar
really, I heard about the austin area with no much car thefts not like the dfw left and right.
Old Jan 20, 2010 | 11:17 PM
SoTexDC2's Avatar
When I built my first Integra, the thought of theft never crossed my mind. Times have changed.
It's not as bad here but I'm not taking any chances. I put too much of my time into my last build and I plan on keeping it forever. Just my weekend toy, no need for all of the attention.
ecovillain
Dec 20, 2004 11:50 PM
Brett
Jul 21, 2003 06:31 PM
dinosa21
Feb 6, 2003 08:55 PM
Hexxboy
Jan 26, 2003 09:12 PM
magic hat #9
Apr 17, 2002 08:16 PM
