trunk
okay i got a 95 acura integra ls coupe.. and i'm trying to work out the bugs lil by little.. okay now i'm having problem with my trunk... in my trunk.. the carpet sags like crazy.. i looked under the carpet i see some time of wood.. looks ghetto.. but car still sags.. i can't even put nothing in my trunk.. can somebody tell me what i need to buy.. or what original came in the car.. and would the acura dealer have it.. if so what is it called.. and how to install it thanks..
yes i do.. but from the back seat up until where the spare tire is at.. is where it sags i don't get it.. this car is like a ****** frainkenstein so many **** missing and ****. grrr..
what does the car usually come wit..
If dealers do have those they will probably have to order it for a good price. Just make one yourself. Mine cracked because I had my sub and box on top so I took it out and traced it on a piece of plywood and cut it out. I am now using both and its way stronger. So just borrow it from someone and trace...problem solved.
Get a sheet of 3/8 inch thick MDF (medium density fiberboard) and cut it to fit the floor area in your trunk. It will be durable enough to keep the carpet from sagging.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom »</TD></TR><TR><TD CLASS="quote">Get a sheet of 3/8 inch thick MDF (medium density fiberboard) and cut it to fit the floor area in your trunk. It will be durable enough to keep the carpet from sagging.</TD></TR></TABLE>
Definately, you cant lose cuz it looks like someone already pulled a MacGyver and jimmy rigged that thing in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped »</TD></TR><TR><TD CLASS="quote">well how do i search for it on the acura dealer website thanks...
i've been searching for a minute now..</TD></TR></TABLE>
http://www.acuraparts247.com/p...ch=no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped »</TD></TR><TR><TD CLASS="quote">if i get the number 10. will i need any bolts or screws or no.. you think that light cardboard will be able to support a sub box? like a 15" kicker l7 sub box?</TD></TR></TABLE>
think about that. if you are planning on having alot of weight concentrated in one spot you may wanna try the idea with the MDF. but beware that **** is ******* heavy.
just make sure you keep your spare tire in there to support the weight.
no junkyard around here have integras.. ppl here don't crash integras lol.. anyways unless u can get it to me from CA shipped and everything for cheaper.. i wouldn't mind..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">The oem board is very strong. I've had 3 rims with tires in the back for 2 days and didnt see any cracks or splitting. In a DB</TD></TR></TABLE>
You forget Allmotor that 4 doors are superior to hatchbacks. Even the material used to make the under-carpet support is better in the 4 doors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped »</TD></TR><TR><TD CLASS="quote"> you think that light cardboard will be able to support a sub box? like a 15" kicker l7 sub box?</TD></TR></TABLE>
If you build your sub-woofer enclosure properly it will support it no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC »</TD></TR><TR><TD CLASS="quote">think about that. if you are planning on having alot of weight concentrated in one spot you may wanna try the idea with the MDF. but beware that **** is ******* heavy. </TD></TR></TABLE>
So is a Kicker L7 15" sub-woofer, with the enclosure, and the amp to run it. What is the harm with an extra 5 pounds of MDF in your floor?
