is it true?
Old Feb 8, 2008 | 04:48 PM
DC2FRMDABAY's Avatar
* B A N N E D *
Default is it true?
so im planning to install my JDM front very soon and i just heard that, if u dont grind the welding spots u did then i would start to rust? is it true? if it is what grinder should i use?
Old Feb 8, 2008 | 05:20 PM
VRD^sam's Avatar
Default Re: is it true? (DC2FRMDABAY)
clean it prime it and paint it
Old Feb 8, 2008 | 07:50 PM
db98runner's Avatar
Default Re: is it true? (VRD^sam)
i'm actually in the process of doing my front on my 98 sedan after a bad car accident, if yours is still a okay front end, [no damage] all you need is the "t-bar" it's the upper portion of the radiator support. so you dont really need to grind or drill out any spot welds at all rele.. but in my case for example, i needed the whole damn radiator support, i drilled out all of the spot welds with a regular drill bit, [takes quite a bit of time] and whatever spot weld that is still sticking to the frame, just get a flathead screwdriver and kinda beat it loose with a hammer. sounds kinda sketchy to do, but it works man. oh and i've come across a few posts where some guys are bolting their new radiator support on.. i DO NOT recommend that at all. if come across a tight corner or what not, it will twist around. i hope i helped a little bit at least. just keep researching tho. this is my first time doing it, and i havn't come across b.s. yet. oh and as far as rust, just spray some paint on your welds and your fine. it wont kill it that bad on welds that small.
__________________________________________________ __________________
-1998 teg ls sedan w/jdm front and vis carbon fiber hood. --current
-1970 Dodge Charger -- gone.
-1996 civic built d16y8 -- SOLD
Old Feb 8, 2008 | 07:55 PM
iBrandon's Avatar
Default Re: is it true? (db98runner)
order yourself a small pint of rust bullet! stuff works great.
Old Feb 8, 2008 | 11:30 PM
B18 Piston's Avatar
dont worry about it
Old Feb 9, 2008 | 05:14 AM
* B A N N E D *
Default Re: (B18 Piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 Piston &raquo;</TD></TR><TR><TD CLASS="quote">dont worry about it</TD></TR></TABLE>your right, i shouldnt be worried.. NOW THE INSTALLATION IS ON! hahaha
Old Feb 9, 2008 | 05:15 AM
Doostur's Avatar
Default Re: (DC2FRMDABAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2FRMDABAY &raquo;</TD></TR><TR><TD CLASS="quote">your right, i shouldnt be worried.. NOW THE INSTALLATION IS ON! hahaha </TD></TR></TABLE>
Im in for pics.
Old Feb 9, 2008 | 06:13 AM
* B A N N E D *
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">
Im in for pics.</TD></TR></TABLE>
hahahha
Old Feb 9, 2008 | 07:52 AM
berb_15's Avatar
you need a clean bare metal to weld which means yes it will rust if you don't paint over it, and so will the welds... so just simply clean the carbon off of it with a wire brush when you're done welding and paint over it
John Kremer
Paint and Body
Mar 24, 2018 02:10 AM
97teggysc
Welding / Fabrication
Feb 12, 2013 04:30 AM
ev0luti0n
Apr 18, 2004 08:41 AM
TK715
Feb 28, 2004 12:19 PM
