trouble starting
Old Aug 6, 2002 | 10:41 AM
digitalhav0c's Avatar
Default trouble starting
anyone had this problem when it is very hot my 90 ls doesn't want to start?
what could be the problem
Old Aug 6, 2002 | 12:51 PM
fuguman's Avatar
New User
Default Re: trouble starting (digitalhav0c)
i do have somethings similar, it starts but takes longer, i have a new battory, so that shouldnt be the problem
Old Aug 6, 2002 | 01:10 PM
farside's Avatar
I had a similar problem. My car would take a long time to get started. The starter seemed to sound real weak. I thought it was a ground, or mabe the starter, cause the battery was only 2 years old. Anyways, I cleaned up the grounds and replaced the starter, but no luck. I finally go and get the battery load tested. It turns out the battery had some bad cells.
Old Aug 6, 2002 | 01:45 PM
jaymar88's Avatar
Default Re: trouble starting (f1-fan)
starters, particularly older ones will tend to stick when they get hot. The most obvious example i can give is with camaros/ firebirds. The starter on those cars always fail when aftermarket headers are installed. They headers are routed so close to the starter that they can make a new starter fail.
A common fix would be to wrap the starter in ehat wrap.
In your case, I suggest you check all connections to and from starter.(ignition switch, battery lead and ground)
Check the condition of the battery. It may register 12 volts, but remember the starter doesn't operate on volt, but amperage.
I would believe if all else checks out, replace the solenoid, have it rebuilt or buy a new/reman. A new starter shoud run you about 100-150.
Good luck
Mike518
Aug 29, 2012 11:29 AM
Cameron60
Sep 24, 2008 09:34 PM
airsodam
Jan 30, 2006 10:55 PM
john457
Aug 16, 2005 10:20 PM
TypeSH
Feb 22, 2005 09:14 PM
