transmissions
Old Sep 30, 2004 | 04:02 AM
g2_teg_'s Avatar
Default transmissions
i was wondering what tranny to use in a G2 teg. B18B/Turbo. anyway, i was originally thinkin about using the B18A tranny, because it is a cable setup, and the gears are pretty good. the more i think about it tho, i think i like the gear setup of B16 better. so what i was thinkin about was a 88-91 (SiR I) Y1 tranny, with an LS final drive (5th gear for highway cruising). these are my questions:
1.) i would use the stock shift linkage correct?
2.) are the gear ratios in a SiR I the same as SiR II
3.) how are they different?
4.) does this seem like the most practical setup for you guys, too? Discuss.
Old Sep 30, 2004 | 04:10 AM
Electron_LS-Vtec's Avatar
Default Re: transmissions (g2_teg_)
if you are going LS turbo you should stick with the LS transmission... The shift linkage will hook up no problem.....the y1 or the Sir I has shorter gears. any others about exact specs?
Old Sep 30, 2004 | 07:20 AM
LSvtec03's Avatar
Default Re: transmissions (Electron_LS-Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electron_LS-Vtec &raquo;</TD></TR><TR><TD CLASS="quote">if you are going LS turbo you should stick with the LS transmission...</TD></TR></TABLE>
shut up!!! jebus, i'm so sick of hearing people say that...such horrible misinformation....
to answer your questions knowledgefully;
1. stock linkage will work
2. i'm pretty sure the SiR II has the shorter gears because they're the same as the type R (y21), just no lsd
3. specnically speaking
4. yes, that does seem practical to have a short-geared tranny with an LS 5th for highway cruising
hth
Old Sep 30, 2004 | 08:55 AM
g2_teg_'s Avatar
Default Re: transmissions (LSvtec03)
damn....i forgot all about LSD. how would i be able to get LSD for it?
Old Sep 30, 2004 | 09:00 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_teg_ &raquo;</TD></TR><TR><TD CLASS="quote">damn....i forgot all about LSD. how would i be able to get LSD for it?</TD></TR></TABLE>
A lot of cable B16 tranny's come with LSD's. They're expensive but well worth it. The other option would be to get ahold of a Quaife.
[shakes head]
Old Sep 30, 2004 | 09:07 AM
g2_teg_'s Avatar
Default Re: transmissions (Kendall)
http://optionimports.com/import-store/quaife.html
so is that an add-on to the stock SiR tranny?
kenji801
Transmission & Drivetrain
19
Nov 27, 2012 11:21 AM
gonmaro
Nov 13, 2008 02:38 PM
brynaert
Sep 30, 2008 05:11 AM
vti2
Sep 20, 2003 02:59 AM
NightHawkC5
Mar 9, 2003 02:35 PM
