transmission fluid?
Old Jun 6, 2007 | 12:08 PM
Integra4lyfe069's Avatar
Default transmission fluid?
which would you use on a 99 integra ls, non vtec, think its running the b18b1 tranny, its starting to shift poorly now like it starting to grind n ****, i havnt had a tranny fluid change since i bought the car, was just wondering what the best would be to use. also wondering what that stuff is called that drains yer tranny of all the grits and stuff after you let all the fluid out or w/e,.. also i hear some good things about this royal purple stuff? any1 know whats up with that stuff?
Old Jun 6, 2007 | 12:14 PM
rgaray's Avatar
I recommend OEM Honda tran. fluid.
Old Jun 6, 2007 | 12:22 PM
myfirstdc2's Avatar
Default Re: transmission fluid? (Integra4lyfe069)
if its grinding bad even after changing with oem honda fluid, then use syncromesh.
Old Jun 6, 2007 | 12:33 PM
thanks, im putting stage 3 clutch and flywheel in too so ittl prolly stiffen thigns up aswell, also throwing in struts so hopefully my boatish ride thats griding will stop haha, just did my oil and oil filter, so ima do a tune up as well and fuel filter and new air filter.
which wires should i use? and just regular platinum ngk plugs ?
Old Jun 6, 2007 | 12:52 PM
Blahblah718293's Avatar
i have 10w30 in my tranny now, but im gonna get some honda mtf as soon as i can get to the dealer. id go with synchromesh but thats like 17 bucks a quart i hear.
Old Jun 6, 2007 | 01:05 PM
ABCVTEC's Avatar
Default Re: transmission fluid? (Blahblah718293)
Penzoil Synchromesh is $7-$8 a quart and it's a small price to pay to protect your $300-$600+ transmission.
Old Jun 11, 2007 | 01:04 PM
SpeedRacerEX-R's Avatar
Default Re: transmission fluid? (ABCVTEC)
how many quarts does a B18C tranny hold? And where do you get this "Synchromesh"?
Old Jun 11, 2007 | 01:05 PM
Default Re: transmission fluid? (SpeedRacerEX-R)
Also, I noticed the drain plug is a square? What's the deal there?
Old Jun 11, 2007 | 01:28 PM
Sam92Teg's Avatar
You just use a 3/8's extension on a ratchet for the drain plug.
Old Jun 11, 2007 | 04:39 PM
team714's Avatar
in my gsr i put 3 quarts of Penzoil Synchromesh. theyre like $7-8 a quart at autozone. you should try royal purple synchromax but theyre like $10 a quart at kragen. ive used royal purple synchromax before on my ek civic feels alot smoother after the change.
Old Jun 11, 2007 | 08:47 PM
myfirstdc2's Avatar
Default Re: transmission fluid? (team714)
i dunno about 3 qts. but on mine i use a lil over 2 qts and its full. and u can find the pennzoil syncro at like autozone or pep boys. about 8 bucks each. as for the plug a 3/8 rachet or breaker bar is fine. and the fill hole is right above it. fill it til it spills out. btw upgrading your clutch with a stage 3 and flywheel will not help u with your grinding.
Old Jun 12, 2007 | 02:51 AM
Default Re: transmission fluid? (myfirstdc2)
thanks guys, I'm off to the zone!
Old Jun 12, 2007 | 03:08 AM
loudassVTEC's Avatar
Don't forget a funnel that has a long piece of hose on it. You're gonna need that to fill the trans, because there's no way to fit a jug of oil anywhere...plus the fill hole is horizontal.
Old Jun 14, 2007 | 04:55 AM
g0tgot's Avatar
honda tranny fluid same as 5w-30 motor oil FYI
Old Jun 14, 2007 | 05:19 AM
Default Re: (g0tgot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot &raquo;</TD></TR><TR><TD CLASS="quote">honda tranny fluid same as 5w-30 motor oil FYI</TD></TR></TABLE>
I thought it was 10w30?
Old Jun 14, 2007 | 06:57 AM
Exeed's Avatar
Default Re: (loudassVTEC)
I didn't fill it from the side like you said loudassVTEC. I just took the spedometer sensor out from the top, fit a lot funnel in there, and poured it. Although you still have to open the filler hole to know when it's full. Granted, it is a bit more work.
Just my 2 cents.
Old Jun 14, 2007 | 06:59 AM
90redg2's Avatar
in the DA manual it says you can use 10w-30 motor oil..but thats before Honda made there own tranny fluid..i always thought tranny fluid had a higher viscosity
Old Jun 14, 2007 | 08:09 AM
Default Re: (Exeed)
That way works also. And actually is faster, and easier. I had always done it the way I described, until about 6 months ago, when I found out about the VSS way. But my car is off the road for the time being (h double deuce swap in my DA ) , so I haven't tried it yet.
dohcgarage@714
Honda S2000
11
Sep 12, 2008 01:39 PM
djviet2000
12
Jun 14, 2007 10:54 AM
RedLudeSH
Aug 23, 2003 09:57 PM
EF-9SiR
10
Nov 3, 2002 07:57 AM
junglistgsr
Sep 21, 2001 12:21 AM
