transmission conversion
i have a da 92 integra with a b16a2 swap. the trans is cable right now but i want to throw a 95 gsr trans in there. i heard hasport makes a conversion kit for it but i see that it only has a mount and levers. do i need another shift linkage? has anyone done this before? any advise?
Shifter linkage is the same, Just needs hydro conversion to run the clutch leaver.
Cant remember but I think the input shaft is different as well and will require you to use a matching clutch disk.
Would be easier just to get your current trans rebuild with LSD.
Clutch disc and plate are the same.
You'll just need to get a 94+ throw-out bearing for the Hydro Trans.
And why would you want a new trans, unless you're using the stock YS1 LS trans?
hondatuner020
13
Jan 6, 2016 08:35 PM
