Tranny question
Old Jul 20, 2008 | 01:34 PM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Tranny question
I just put a new tranny on my LS and it is hard to shift into gears. it take a lot of force to go into each gear even coming into neutral. can ne one give me some idea whats going on and what i can do to fix this
Old Jul 20, 2008 | 03:38 PM
hondateg10's Avatar
ne one
Old Jul 20, 2008 | 03:55 PM
D@9 A.D.B.'s Avatar
Default Re: (hondateg10)
what kind of fluid are you using...how did the clutch look when you swapped trannys, was it good
Old Jul 20, 2008 | 04:01 PM
hondateg10's Avatar
Default Re: (D@9 A.D.B.)
penzoil synchromesh. yeah it looked ok its a 3 puck clutch. but i dont know why the clutch would have ne thing to do with it. the clutch is working fine
Old Jul 20, 2008 | 04:10 PM
D@9 A.D.B.'s Avatar
well you know that with the clutch it will be stffer than stock and grab harder, but does the tranny make any sort of noises...cause mine was having this same problem last week and it started to rattle at high rpm then eventually blew last saturday
Old Jul 20, 2008 | 04:17 PM
hondateg10's Avatar
i did not hear ne thing. when i as hard to get into gear it almost takes two hands. its not grinding. its just hard to shift
Old Jul 20, 2008 | 04:39 PM
goodtrouble's Avatar
Maybe the shifter is too tight?
Old Jul 20, 2008 | 04:44 PM
hondateg10's Avatar
Default Re: (goodtrouble)
how would that make the shifting hard? a little more input please
Old Jul 20, 2008 | 04:53 PM
one of the bolts thats on the shifter makes the shifting harder if it's overtightened... I forget which one it's called, but I'll see if I can look it up for ya
Old Jul 20, 2008 | 04:59 PM
D@9 A.D.B.'s Avatar
o ok its not grinding or making any noise....well check small stuff like the clutch reservoir and make sure its full
Old Jul 20, 2008 | 05:00 PM
http://www.acuraautomotivepart...ormal
It's the bolt that holds the shifter to the shift linkage. Try loosening that a little and see if the shifting gets easier
Old Jul 20, 2008 | 05:37 PM
hondateg10's Avatar
ohhh ok i understand what your saying now. ill check that tomorrow and give you an update
Old Jul 20, 2008 | 06:29 PM
DiMpL3s.'s Avatar
bleed the clutch master cylinder
Old Jul 21, 2008 | 04:13 AM
hondateg10's Avatar
Default Re: (DiMpL3s.)
i have bled the clutch
Old Jul 21, 2008 | 05:10 AM
hondateg10's Avatar
still havent checked the shifter bolt. i will check that this afternoon and let yall know if that fixes the problem
Old Jul 21, 2008 | 09:11 AM
ai98ls's Avatar
The Transmission on my car was rebuilt and i put it in the car a few weeks ago. After I put the tranny fluid in, it was still very hard like you say to put it in gear. I used both my hands also to put it in reverse and first gear, but after driving it a little it got softer and softer to shift, now it shifts in to gear normally. My guess is that even though i had put the fluid in, it had not lubricated all the parts and gears in there until I drove the car. Maybe you have the same problem.
Old Jul 21, 2008 | 09:47 AM
hondateg10's Avatar
Default Re: (ai98ls)
i was thinking the same thing. thanks for the input....
to all the ones who are helping me out and giving me some ideas im gonna give yall a
Old Jul 21, 2008 | 10:06 AM
ai98ls's Avatar
No problem man, let us know what the problem was when you fix it.
Old Jul 22, 2008 | 03:54 AM
hondateg10's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodtrouble &raquo;</TD></TR><TR><TD CLASS="quote">http://www.acuraautomotivepart...ormal
It's the bolt that holds the shifter to the shift linkage. Try loosening that a little and see if the shifting gets easier</TD></TR></TABLE>
That was it! Thanks man
NYCz DA9
Jul 31, 2004 10:59 PM
NYCz DA9
Jul 16, 2004 04:38 PM
RTW DC2R
Feb 9, 2004 02:13 PM
JustChou
Apr 18, 2002 07:40 AM
sLo B18b
Jul 1, 2001 06:37 PM
