help!!!
Old Jul 21, 2008 | 02:53 AM
vdawg559's Avatar
Default help!!!
spec 94 integra ls 5 spd
- car boggs, sometimes during 2-3 rpm
-car wont start, when i turn the key an hold the clutch. nothing would happen
sometimes when i press the clutch down an turn the key. an hold it sometimes.
it would start. also it would start when i push start it.
other then that it would start up normaly sometimes.
- car will idle normal. an few minutes. it would go up an down.
-while driving the my car it would sometimes die.
sometime it would drive normal.
no engine check light or what so ever.... it would also come on at times
an it would just drive normal
- the themp gauge will just all the way to high. an go back down when i turn of the car an put it back in gear an it would just go back normal..
finally. when i put the jumper wire on. an the code reads 8 an 43.
but when i drive it. no code come on at all.
help me out please.
Old Jul 21, 2008 | 10:04 AM
lilvietboy's Avatar
are you fuel pumps/ fuel filter restrictions , timing belt, distributor, spark plugs all working?
Old Jul 22, 2008 | 01:58 AM
vdawg559's Avatar
fuel prime. an everything.
found out starter mess up.
and ima just replace the dizzy.
Old Jul 22, 2008 | 05:08 AM
vtecb18c's Avatar
Default Re: (vdawg559)
hows your timing? and may the idle up and down is either your TPS or IACV which could also be making the car die
whytry2002
Oct 19, 2010 08:44 PM
VTEC_PRODUCTION
Apr 6, 2007 06:24 AM
white_98_gsr
21
Sep 2, 2005 05:01 PM
94_CRVtec
Apr 23, 2005 10:26 AM
yusoslo
Sep 28, 2003 12:29 PM
