Tranny Overhaul & JDM ITR Final Drive/LSD Install (56k...not so much)
#31
Mad Scientist
Re: IN VTEC (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">
one tip for getting the snap ring back onto the countershaft, when sealing the case:
expand the ring over the bearing
tighten a couple bolts that hold the case together, 8 will do
flip the case upside down, and gently tap it on a piece of wood, you should hear the snap ring click into place
best trick evar
best trick evar
#33
Re: IN VTEC (91integraLSVTEC)
How would I remove the gears from the shaft without a press? Also how would I put the gears back on without a press?
Going to do a syncro change this weekend and this thread is going to help a ton!
#35
Re: IN VTEC (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">How would I remove the gears from the shaft without a press? Also how would I put the gears back on without a press?
Going to do a syncro change this weekend and this thread is going to help a ton! </TD></TR></TABLE>
you don't need a press
to take off the gears you will need a gear puller
and to put them back on i use a pipe with a inner diameter a little bigger than the diameter of the shaft
#36
Re: Tranny Overhaul & JDM ITR Final Drive/LSD Install (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">What is the 10mm allen head for? </TD></TR></TABLE>
10mm allen bolt is for the oil gutter plate
no need to take that out, just leave that in
#37
Re: Tranny Overhaul & JDM ITR Final Drive/LSD Install (Dan GSR)
How much for a gear puller and exactly which one? Is there a way to do it without a gear puller? I just went to sears yesterday for all the stuff but don't mind going again to make sure I have all the right tools.
#38
impossible without gear puller, as some gears are pressed on, and won't come off with just prying it, which would also cause damage
i would go buy a three jaw gear puller, of the large variety
#40
Will a 2 jaw puller work or should I get the 2-3 jaw puller?
Small or large?
Let me pull up some links.
Small or large?
#41
Craftsman 2 Jaw Small Gear Puller
http://www.sears.com/sr/javasr...blink
Craftsman 2 Jaw Large Gear Puller
http://www.sears.com/sr/javasr...CRAFT
Craftsman 2-3 Jaw Gear Puller
This is getting expensive.
#43
Re: (grn4drgsr)
2 jaw puller will work, I use one, because thats all i have, but if i were to buy one i'd get a 3 jaw, the 2 jaw is a pain sometimes, because u have to keep it from moving around as your pull the gear off, with a three jaw, it will balance itself out
i will probably buy 3 jaw eventually
you will need a large 3 jaw puller
not sure if any of the ones you listed are large enough
you will probably need something that has a 6" jaw, as the shaft is pretty deep
might be able to find something at autozone, or similar
it is a very simple tool, and hard to **** up such a simple design
a cheap one should do you ok, but the more expensive ones def show their quality in materials
#45
do you have a helms manual?
the syncro sleeve ring goes on a very specific way
the sleeve has 3 pairs of raised teeth that needs to go in a specific spot on the syncros, it can be installed wrong, and will go on wrong
and you will find out the hard way if you did it incorrectly
This is getting expensive. </TD></TR></TABLE>
hella cheaper than having a transmission place do it,
plus after you've done it once, its easy, and can charge other ppl to do it for them
#46
Re: Tranny Overhaul & JDM ITR Final Drive/LSD Install (IN VTEC)
I never take the pin out of the shift rod, unless, i'm changing transmission completly
i just remove the rod from the car, and leave it attached to the trans
that pin is spec'd to a very tight tolerence
and doesn't need to be taken out uneccesarily
also its sometimes stubborn, so i don't even deal with it, much much easier to take out the 12mm head bolt from the shifter
#47
also you its good to have another person to help you open the case
its damn impossible to expand the ring ,and pry the case open at the same time by yourself
same goes for closing the case
an extra person will also come in handly when it comes time to put in both gear shafts, and shifter forks back in the case, although it can be done solo, and have learned how to do that portion by myself
#48
Re: (Dan GSR)
Nice write up.
More info:
When using Honda bond I use a dental tool and punch a small hole in the tube and squeeze it out in a nice thin line.
A nice dental pick helps with the small stuff.
As for a puller.. use this one:
Expensive ($104 me thinks it is a (4")) (6" = $139) but worth every penny.
The main thing that holds the case apart when you try to put it back together is this shaft:
I use the dental tool/screwdriver to move the shaft around a little bit so the case will fall back together. If the case does not touch all the way around (without force) there is something hung up.
The bearing on the top of the shaft usually stays in the case when you separate the cases.
The metal washer (with the tab) that is right under the bearing has a set position that it needs to be in before the cases are bolted together. Look inside of the outer case and you can see the channel that the tab goes into.
I always bolt the case together with 4 or 5 bolts (no Hondabond) and check to make sure that all of the gears work and there is no binding. I 'hate' semi-crusty Hondabond.
As for the 'tool' to put the gears back onto the shaft... I was given a home made tool that is a piece of aluminum tubing that fits into the gear just right and it has a cap that can be used for hammering on.
Anybody want a picture of it?
Modified by Willard at 3:37 PM 3/17/2004
More info:
#49
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Going to do a syncro change this weekend and this thread is going to help a ton! </TD></TR></TABLE>
You don't need the puller to do a 3/4 syncro change.
and the Helms book has a misprint on the 3/4 slider piece orientation... just put the new one in like the old one came out (or set the outter ring grove to match the Helms).
#50
Re: IN VTEC (Willard)
More stuff added.
I'm getting there....bit by bit.
Thanks Dan and Willard for the help thus far. It really helps to have you guys add in what you guys can to make this a truly definitive tranny post.
