tranny code serial numbers
Old Jan 7, 2005 | 01:05 PM
BLacK FirE's Avatar
Default tranny code serial numbers
Ok, I'm trying to figure out if my car has a gsr tranny or not. I did the rpm test and for 70mph I'm around 3.5k. I jacked up my car today but could not find the vin number stamped on the tranny, probably because I didn't know where to look for it. So my question is do the serial numbers after the s80 mean anything and would I be able to use that to determine what kind of tranny it is?
Old Jan 7, 2005 | 08:47 PM
BLacK FirE's Avatar
Default Re: tranny code serial numbers (BLacK FirE)
bump, anyone?
Old Jan 7, 2005 | 09:40 PM
b-power's Avatar
correct me if im wrong somebody, but he does have a gsr tranny if the code starts with s80 or y80 right?(either one)
Old Jan 7, 2005 | 10:16 PM
BLacK FirE's Avatar
Default Re: tranny code serial numbers (b-power)
nah i did a search already. basically all dc transmissions are s80 except the itr is s80 with some other stuff after it to denote that it has lsd.
Old Jan 7, 2005 | 10:36 PM
hlub29's Avatar
you drive to 80mph on a B18C and the rpm should be at 4k
Old Jan 8, 2005 | 12:37 PM
BLacK FirE's Avatar
Default Re: tranny code serial numbers (hlub29)
bump
Old Jan 8, 2005 | 08:04 PM
b-power's Avatar
go to http://www.hmotorsonline.com it says it right there for the obd1 gsr tranny is s80,y80
Old Jan 8, 2005 | 09:39 PM
BLacK FirE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-power &raquo;</TD></TR><TR><TD CLASS="quote">go to http://www.hmotorsonline.com it says it right there for the obd1 gsr tranny is s80,y80</TD></TR></TABLE>
how come people can't read? Like I already stated everysingle dc is stamped with either s80 or y80. You can not use that to distuingish between what kind of tranny it is.
http://www.hondaswap.com/forum...29829
Old Jan 8, 2005 | 09:51 PM
vidanator's Avatar
hey, i dunno if this helps but when i'm going about 110km/h the rpm is about 3500, which basically abuot 70m/h
Old Jan 9, 2005 | 06:42 AM
BLacK FirE's Avatar
Default Re: tranny code serial numbers (vidanator)
Well yea according to the rpm/mph test I have a gsr tranny but I wanted to be absoultly sure, that's why I was hoping if anyone knew if the serial number had any kind of meaning because my trannycode is s80-3112307.
Old Jan 9, 2005 | 08:26 AM
3.504's Avatar
i dont know serial numbers (i'm a cable clutch guy). i had an LS before, it pulled 92mph at 4000 on stock size wheel diameter.
Old Jan 9, 2005 | 09:08 AM
PLAGUED_DB7's Avatar
Default Re: tranny code serial numbers (3.504)
I have an LS...in 5th going 80 I am pretty sure I am 3.5k
Old Jan 9, 2005 | 10:56 AM
b-power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.hondaswap.com/forum...29829</TD></TR></TABLE>
like i said in my post before homeboy, correct me if im wrong. no need for the smart mouth ****. you asked us a question, we didnt ask you.
Old Jan 12, 2005 | 06:34 PM
jdmjohnny's Avatar
probably becuase he mentioned it about 50 times i can see y hes gettin pissed off..
89hatcher
Aug 7, 2007 07:18 PM
LuMop
Aug 10, 2006 04:51 PM
NightHawkC5
Oct 1, 2003 04:24 AM
hi-Powered
May 6, 2003 01:39 PM
