TPS&KNOCK SENSOR
Old Mar 18, 2004 | 02:23 PM
dashway's Avatar
Default TPS&KNOCK SENSOR
Ok the CEL on my JDMG2 is throwing #7 and #23......im not getting VTEC but other than that everything is fine...no idle probs no starting probs.......the knock sensor is not there tried grounding the wire...the code went for a while now its back.
question ...is the TPS bad or does it need adjusting...and what are the side effects of leaving it as it is
Old Mar 18, 2004 | 02:39 PM
SuzukaBlueAP2's Avatar
Default Re: TPS&KNOCK SENSOR (dashway)
I also threw the "throttle angle code", but it was on my G3 GS.
What ECU are you runnin with that motor ?
and what JDM motor are you running ?
Old Mar 18, 2004 | 02:42 PM
dashway's Avatar
Default Re: TPS&KNOCK SENSOR (ScreaminTeg)
the stock ecu...its a jdm xsi ie b16a motor
Old Mar 18, 2004 | 04:14 PM
cjohnson_2's Avatar
Well, did you take off the Tps sensor and knock sensor to transfer it to another throttle body? or move them in anyway? If you did, you have to "reset" them.
Old Mar 18, 2004 | 04:26 PM
dashway's Avatar
Default Re: TPS&KNOCK SENSOR (cjohnson_2)
well the knock sensor is not there ....i know that for a fact tried grounding the wire ...went away for awhile but now the code is back im just wondering what the side effect of not having it is....also is it bcuz the tps is not adjusted why im getting the code or is it that its faulty...parts are very hard to come by so if all the tps need is adjusting then im ok
Old Mar 19, 2004 | 02:14 AM
dashway's Avatar
ttt
hatch34
Mar 16, 2005 12:49 PM
birds_sol_94
Aug 19, 2004 04:23 PM
99spanishGT
Mar 26, 2004 12:40 PM
99spanishGT
Mar 11, 2004 07:07 AM
Fardoche
Jul 31, 2003 10:29 PM
