TPS Code 7 question.....
Old Feb 17, 2005 | 10:33 AM
hybridej7's Avatar
Default TPS Code 7 question.....
i did a search on tps sensors, got a couple returns and things to try but didnt really answer my question though. just recently swap a 93 ls longblock into my 91 integra. everything is all well, fired right up on the first try, then the light comes on and i check the code. its code 7, tps sensor. i used the same intake mani and everything, all i swapped was the longblock. cars runs good, idles at about 800-900, not rough or anything, drives excellent, no bogging down, nothing....before i get into taking the tps off, wanted to see if there were any other suggestions on what i can try before trying to adjust the tps.... the car didnt run before i put the swap in so i dont know if it did it before or not....thanks all for any input....
Old Feb 17, 2005 | 01:36 PM
gsrboost's Avatar
Default Re: TPS Code 7 question..... (hybridej7)
Check the voltage on the TPS with a volt meter. When the throttle is completely closed you should have low voltage (less than 1volt), when it completely open you should have about 5volts.
Old Feb 17, 2005 | 02:59 PM
dc4drewH's Avatar
Default Re: TPS Code 7 question..... (gsrsp33d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrsp33d &raquo;</TD></TR><TR><TD CLASS="quote">Check the voltage on the TPS with a volt meter. When the throttle is completely closed you should have low voltage (less than 1volt), when it completely open you should have about 5volts.</TD></TR></TABLE>
warrick's Avatar
reset the ecu, double check your grounds, double check tps voltage. if the voltage is out of whack, it needs adjusting. otherwise, check your wiring.
Old Feb 17, 2005 | 05:46 PM
hybridej7's Avatar
Default Re: TPS Code 7 question..... (warrick)
wiring is all the same, nothing changed. need to get ahold of a voltmeter, one of the only things not in my toolbox.....
reset ecu twice, not sure what grounds would be loose, but i will double check them all....
bump for all the help....
elmejor
Aug 31, 2008 08:57 AM
rhdins
Jul 20, 2008 05:12 AM
skiracer8148
Aug 2, 2006 03:26 AM
psegs80
Jul 15, 2005 05:07 AM
TegLove
Apr 23, 2004 11:24 AM
