on the topic of trannys
Old Jul 25, 2008 | 07:40 AM
BeRightBack's Avatar
Default on the topic of trannys
so I am having a hard time shifthing, a lot of times it's getting into reverse, and some times it's getting into third or fourth gear. When I am idling in first gear, and a stop and I rev and roll back a lil bit you can hear what sounds like something rattling around in the tranny. What do you think it could be?
And now my 2nd question. If by chance I need to get a new tranny, ( I have decided that if I do I am going GSR) do I have to adjust any of the mounts, or is there anything special that I need to do to mount it up to my LS block?
Old Jul 25, 2008 | 07:51 AM
RS'R''s Avatar
bump for a fellow mainer
when did you last replaced your clutch? and you dont need to change any of the mounts.
Old Jul 25, 2008 | 08:13 AM
I haven't replaced it yet. The person that I bought it from had it replaced before he bought the car and it only has about 70k on it
Old Jul 25, 2008 | 11:08 AM
RS'R''s Avatar
well youll know when you take your tranny off. buy a b16 tranny. its the best single upgrade for your ls. youll have to pull some dowel pins from the block and tranny to get them to line up, but besides that its all plug and play.
Old Jul 25, 2008 | 11:22 AM
TOO MUCH TORQUE's Avatar
Default Re: (RS'R')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS’R’ &raquo;</TD></TR><TR><TD CLASS="quote">well youll know when you take your tranny off. buy a b16 tranny. its the best single upgrade for your ls. youll have to pull some dowel pins from the block and tranny to get them to line up, but besides that its all plug and play.</TD></TR></TABLE>
too short for ls...ls only revs to 6.9k safely so it would put extra stress on the ls engine
Old Jul 25, 2008 | 03:52 PM
omnirage's Avatar
Default Re: (TOO MUCH TORQUE)
How would it put stress on the engine? You just wouldn't have much rev room to accelerate after an upshift.
Old Jul 25, 2008 | 05:50 PM
Horseofcourse's Avatar
Default Re: (omnirage)
Sounds like a synchro or a shift fork
Old Jul 26, 2008 | 12:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omnirage &raquo;</TD></TR><TR><TD CLASS="quote">How would it put stress on the engine? You just wouldn't have much rev room to accelerate after an upshift.</TD></TR></TABLE>
thats true but it was mated to an ls tranny back in production, you slap on a super short gearing tranny, its not going to be use to the high rpms hence the extra stress.
Old Jul 26, 2008 | 04:34 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">
It's not going to be used to the high RPM in 5th, not just in general. There's nothing about the transmission that magically raises the rev limiter. Be more clear with your statements.
Old Jul 26, 2008 | 07:43 AM
since it is a manual transmission you make the shifts.... and you can shift at any time. So no additional Stress will happen. unless you mean that when you shift out of say 2nd at close to 6.8k and throw into third its going to be at a higher RPM than the LS tranny would be you would be correct. But that makes really know difference. Get the b16 tranny, put the ls 5th gear in it and run it all day long my friend. Be Safe Have Fun
DCtito
May 6, 2006 06:57 PM
turbo_b16_ex
May 3, 2005 11:30 AM
gtfourmn
May 26, 2004 01:28 PM
ActiveAero
Mar 3, 2004 04:02 PM
not so civic
Jan 6, 2004 08:56 PM
