tranny install problems?
Old May 25, 2004 | 07:15 PM
gtfourmn's Avatar
Default tranny install problems?
Hi.
I just installed a new ls tranny in my 94 integra and it doesn't seem to want to grab. I can start it in gear without jerking the car, and the car doesn't die in 1st gear. 1st and second gear does nothing, in 3rd-5th if I press on the gas pedal my speed goes up with the rpm while the car isn't going anywhere, and in reverse it makes a wired low noise.
Pior to installing the ls tranny I had a gsr tranny with bad snchro in 2nd, 3rd and 5th so I opted for a better condition tranny in the LS tranny w/no grind. It was driving fine, except for the gear grinds.
I didn't touch the clutch assebly at all, just took the gsr tranny out and pop the ls in. So I'm at a lost... seems like the clutch is out of place for something.
Any help would be appreciated.
Old May 26, 2004 | 10:39 AM
gtfourmn's Avatar
Default Re: tranny install problems? (turbine)
bump... any suggestions/ideas?
Old May 26, 2004 | 10:43 AM
jDMJeRk's Avatar
Im kinda lost....
You say the speed goes up with the RPMs; but the car isnt going anywhere?
My friend had his differential go and he said some of the similar things; but your car is moving in some gears?
Maybe post a good reply so we can get a better idea. It sounds very interesting.
Old May 26, 2004 | 11:12 AM
gtfourmn's Avatar
Default Re: (jdmjerk)
The car doesn't move in any gear.
The speed guage just goes up with the rpm guage in 3rd-5th.
Old May 26, 2004 | 01:23 PM
Ron Carroll's Avatar
Default Re: (turbine)
Check your drive shafts, one of them is not all of the way in, If when you installed them you do not get them to snap in they can pop out a slight bit and you will not be able to go anywhere, since the speed sensor is drivin off of the diffy it will still show speed with no movement.
Old May 26, 2004 | 01:28 PM
cougar10ag's Avatar
Default Re: (itaintegra52)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itaintegra52 &raquo;</TD></TR><TR><TD CLASS="quote">Check your drive shafts, one of them is not all of the way in, If when you installed them you do not get them to snap in they can pop out a slight bit and you will not be able to go anywhere, since the speed sensor is drivin off of the diffy it will still show speed with no movement.</TD></TR></TABLE>
KingDela
Transmission & Drivetrain
Apr 25, 2013 12:58 PM
ILS_09
Dec 12, 2009 05:51 PM
Boosted_B_Series
Nov 27, 2009 05:01 AM
909Dc2Racer
Aug 3, 2009 10:11 PM
crx_88_si
Jul 27, 2004 08:32 AM
