Tire Bubble...
Old Apr 22, 2002 | 05:53 PM
TeamTooQuick's Avatar
Default Tire Bubble...
My back left tire has a pretty good size bubble in it, should this be fixed right away, or can it go for a little bit with the bubble?? TIA
Old Apr 22, 2002 | 05:55 PM
GSRaCeRbOI's Avatar
Default Re: Tire Bubble... (TeamTooQuick)
i had a bubble on my sidewall about the size of a golfball (maybe a lil smaller) i replaced it right away as I didnt want to risk a blow out.. there is no fix for a tire bubble.. so you'll have to get it replaced... this happened on my frenz Kumho Ecsta 712s also.. i'd get it replaced so u dont risk a blow out and lose control of your car...
Old Apr 22, 2002 | 05:57 PM
JMX's Avatar
JMX
where in the side wall or the tread? is it on the stock integra tires(not a low pro tire) if its the stock tores and in the tread you have a separated tire, the radial belts have slipped, nothing to to but get a new tire
havent seen separated tires on low pros that why i asked
Old Apr 22, 2002 | 06:25 PM
ATeg92's Avatar
GET IT REPLACED NOW!!!!
the tire might blow and you could total you car and injure somebody.
Old Apr 22, 2002 | 07:09 PM
SIK IN DA HED's Avatar
New User
Default Re: Tire Bubble... (ATeg92)
i also got the same problem.
Old Apr 22, 2002 | 07:10 PM
Chris's Avatar
Default Re: Tire Bubble... (dlplayboy)
Tread is seperating.
FIX IT NOW.
You will have a blowout and injure not only yourself.. someone else.
Old Apr 22, 2002 | 07:35 PM
dubster99's Avatar
Default Re: Tire Bubble... (Chris)
FIRESTONE!! FIRESTONE!! FIRESTONE!!
Get that fixed right away....
Old Apr 22, 2002 | 09:28 PM
smkngsr's Avatar
Default Re: Tire Bubble... (dubster99)
i had the same problem once and...since i didnt have enough cash at that moment..i got away of using a car for few months but then the downside is u cant speed up...i remember the fastest i have driven the car was 55..im afraid that it will blow and i will spin like crazy...bottomline is u can keep it for a while...just dont go too fast...but if u have the cash now...might as well get them replace to be on a safe side...hope this helps
Old Apr 23, 2002 | 12:41 AM
vteg's Avatar
New User
It has been said a few times. Get it replaced ASAP. You have no guarantee on how long the tire will last in this condition.
Old Apr 23, 2002 | 12:45 AM
GokuSSJ4's Avatar
Default Re: Tire Bubble... (vteg)
get it replace right away , is better to be safe then sorry!
Old Apr 23, 2002 | 06:04 AM
Default Re: Tire Bubble... (Spoon1)
Its in the sidewall, and i have Good Year tires, the tire is in the back, and it has the best tread out of all my tires...
BongoBennie
Mar 16, 2017 12:06 PM
hawk2828
Feb 19, 2010 02:08 PM
G2_Fella
Nov 15, 2006 09:13 AM
TypeR1558
Aug 6, 2001 07:21 AM
