Timing Question
Old Mar 27, 2002 | 09:21 AM
Fooser's Avatar
Default Timing Question
Ok so I did a valve adjustment a week or two ago and I noticed the when I lined up the Cam Gears to TDC #1 the crank pulley TDC mark was about a 1/16 of a inch past the plastic marker. Is this reliable? Will it cause problems with the engine? Should I be worried about it?
Could this cause a low idle? my idle during the day has been pretty low during the day but at night its higher. This makes me think that I should not change the idle itself. I think something else is causing this problem. Any suggestions would be appreciated.
Oh ya I change the PCV valve already, and today I plan on changing the MTF fluids along with the coolant.
[Modified by Fooser, 6:22 PM 3/27/2002]
Old Mar 27, 2002 | 12:26 PM
Fooser's Avatar
Default Re: Timing Question (Fooser)
someone has to know about this.
Old Mar 29, 2002 | 09:21 AM
Fooser's Avatar
TTT
Has anyone ever had this problem?
[Modified by Fooser, 6:22 PM 3/29/2002]
Flatland2D
10
Apr 30, 2007 06:06 PM
frankenstienEk
Feb 13, 2007 09:55 AM
Combustion Contraption
Jan 24, 2004 10:00 AM
Malgerus
Aug 30, 2002 10:01 AM
