Ticking noise, poor gas milage, and feels sluggish
Old 11-07-2010, 03:39 PM
JDM215's Avatar
Default Ticking noise, poor gas milage, and feels sluggish
I have a 99 integra it has an exhaust intake and headers, ive noticed i been getting really bad gas mileage also a ticking noise and the car feels really sluggish. I changed the spark plugs, wires,distributor, o2 sensor, i changed the oil, oil filter and sea foamed the car and there was a difference a pretty big difference but it still doesnt feel as good as the other integras ive driven and mine has more mods. i have to keep pressing on the gas to move. the car starts to slow down as im going up hill even if i down shift. my idle kind of fluctuates and drops like it wants to stall but comes back up but not a lot most of the time its idling at around 700 800 on a cold start at 1500, when i try to drive when the car is cold i have to keep gassing it in first gear or ill stall out. and if im going over 50 or so and just throw it in neutral the car shuts off this hasnt started happening until today. the ticking noise is coming from the motor it sounds the same all the time it doesnt get any louder it just ticks no matter what rpm im at.
let me know what you guys think
Old 11-07-2010, 04:03 PM
meyerk9's Avatar
Default Re: Ticking noise, poor gas milage, and feels sluggish
ticking could be valve train. try adjusting the valve lash. poor gas mileage could be a number of things, o2 sensors, etc. alot of times poor gas mileage is something the computer is doing because its is sensing something out of wack. the idle is probably a dirty IACV so i suggest cleaning that
Old 11-07-2010, 04:26 PM
tacosandbeans's Avatar
any check engine lights? might also want to change your fuel filter too
Old 11-07-2010, 05:31 PM
JDM215's Avatar
the check engine light came on for my egr or something and a misfire so thats why i gave it a tune up and the light hasnt come on yet idk what the egr is to tell you the truth
supposedly the fuel filter is new but im not sure
Old 11-07-2010, 05:32 PM
JDM215's Avatar
do you guys have any idea why my car would turn off if i just put my car into neutral everything else works it always turns on after it turns off
Old 11-07-2010, 05:40 PM
jlowellintegra's Avatar
Try your ignition coil!
Old 11-07-2010, 05:48 PM
JDM215's Avatar
ill try that
Old 11-07-2010, 09:40 PM
96744db8's Avatar
change your gas filter
Old 11-08-2010, 03:38 AM
JDM215's Avatar
would the gas filter cause my car to shut off in the cold i noticed it only happens when its really cold, it happened to me this morning on the way to school i was backing out of my drive way and it stalled out and it took a while to start
Old 11-08-2010, 03:44 AM
JDM215's Avatar
what is a good fuel filter besides an oem one
Old 11-08-2010, 11:16 AM
JDM215's Avatar
anybody?
Old 11-08-2010, 01:28 PM
meyerk9's Avatar
go oem. if they go through the time and effort to create their own filters, then it is worth it to use
Old 11-08-2010, 01:37 PM
JDM215's Avatar
can i go to the dealership to get one? or would i have to order it
Old 11-08-2010, 03:55 PM
1998GsRIntegra's Avatar
That is probably something that the dealership would stock beacuse its a common part. You could always call them first and ask.
Old 11-08-2010, 04:41 PM
JDM215's Avatar
thats true thanks ill try to get this one this week and install it and ill let you guys know
Old 11-09-2010, 03:55 AM
JDM215's Avatar
anybody else have any ideas of what it could be besides the fuel filter
Old 11-09-2010, 08:10 AM
2kdb8's Avatar
as the first guy responded. i'd check your valve train. if not adjusted right, you will loose compression which will result in loss in power and gas mileage. you could do a compression check or a leak down would be better to see if the valves are staying open. if you check your valve clearance and all is good and your still getting bad compression numbers then your piston rings are toast which results in same thing, power loss, poor gas mileage and even misfires.
Old 11-09-2010, 08:22 AM
j_mee_5's Avatar
also try to change your o2 censer its about 60 bucks at advance auto. that may help salve the problems on running bad with its cold. mine was like that too i changed fuel pump and fuel filter and did the same so i changed the o2 and it ran fine after that.
Old 11-09-2010, 09:17 AM
dudesitsjdm's Avatar
No one asked DOES IT OVER HEAT?
Old 11-09-2010, 03:37 PM
Honda_ThuGZ's Avatar
like many have already said check your valve lash ..... ticking sound plus car being weak plus poor gas mileage can very well mean valve lash is not set correctly
Old 11-09-2010, 04:35 PM
JDM215's Avatar
no the car doesnt over heat, i replaced my 02 and ill try check my compression and ill just get a valve adjustment, i dont think my rings are toasted because i havent burned any oil
Old 11-09-2010, 04:48 PM
dntnedvtec's Avatar
ticking= valve
bad gas mileage= dirty injectors, tune up? Distributor/cap and rotor?
How many miles do you have on the car?
Old 11-09-2010, 05:13 PM
JDM215's Avatar
it has 115XXX i gave it a tune up i ran two bottles of sea foam, an oil change, oil filter, new spark plugs, wires, pcv valve, o2 sensor, also did a fuel injector cleaner, gas is somewhat better but still sluggish
Old 11-09-2010, 05:19 PM
JDM215's Avatar
forgot to add the cap on the distributor is new too
Old 11-09-2010, 05:23 PM
bks84's Avatar
It's sluggish... yet not a single mention of checking the timing. are you guys serious? my girlfriends Civic was doing the same thing. I checked the timing and it apparently jumped +1 (advanced) tooth. I fixed it and it runs like it should. Granted its a Y7, but all engines operate the same.
For the head noise, its more than likely a lifter tapping. BUT I wouldnt do a valve adjustment until you check your timing. cuz, its pointless to do so, they'll more than likely be outta spec.
I suggest first and foremost, check your mechanical timing. If you do not know how, buy a chiltons or some other service manual and get to work. I dont know timing belt, water pump and tensioner service intervals, but if its off a lot I would go ahead and replace those items. If it slipped its more than likely due to a worn belt, improperly tensioned belt or a bad tensioner springs.
im still baffled that no one suggested to check your timing.
if your timing seems fine, then I'd check fuel pressure at the rail.
Quick Reply: Ticking noise, poor gas milage, and feels sluggish
