Throwing Engine Codes 6-14-21!!!!Need Help
Old Jun 13, 2002 | 08:51 AM
AK94GSR's Avatar
Default Throwing Engine Codes 6-14-21!!!!Need Help
Man I just knew I would run into other problems when I got done installing my head back on my car as well as the skunk2 manifold.
code6- coolant temp sensor
code14- IAC valve
code 21- VTEC Solenoid
Anyone have any suggestions as to what to look for or check???
When installing the skunk2 mani, what did you guys do with the Intake Air Bypass control connector. Did you just leave it hanging or did you cut it off, or did you wiring it into the IAC valve connector. Need Help let me know
Old Jun 13, 2002 | 03:33 PM
AK94GSR's Avatar
Default Re: Throwing Engine Codes 6-14-21!!!!Need Help (AK94GSR)
Anyone have any suggestions???
Old Jun 13, 2002 | 03:43 PM
morepoop4u's Avatar
start with resetting your ecu to see if it comes back on when you start it back up. if it does then make sure if all the connections are correct and reset your ecu. if its still on then use a volt meter to see if you have enough current running through the connetor by turning the key to II. if you still have a cel light then your gonna have to check the actual device. hope that helps
beocop
Dec 7, 2016 03:41 AM
jw 1
Jul 4, 2013 04:06 AM
Thegreenlude
Nov 25, 2010 09:19 AM
b16racr91
Mar 2, 2003 09:29 PM
