Throwing Codes
Old Jan 6, 2007 | 11:06 PM
Ha Itz's Avatar
Default Throwing Codes
my check engien light was on and i did a cel code check and it was clinder one misfire.. it must b from the crank sensor anyone know wat i need to do to fix this so i can pass emission
Old Jan 7, 2007 | 03:47 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: Throwing Codes (Ha Itz a Jew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ha Itz a Jew &raquo;</TD></TR><TR><TD CLASS="quote">my check engien light was on and i did a cel code check and it was clinder one misfire.. it must b from the crank sensor anyone know wat i need to do to fix this so i can pass emission</TD></TR></TABLE>
yeah. fix the problem. my friend has a misfire code and it was his injector for that cylinder. but it could be a crank position sensor or something. your best bet is to start with the easiest problem to fix and work your way up.
Old Jan 7, 2007 | 09:07 AM
95 integra's Avatar
Default Re: Throwing Codes (god.loves.ugly)
New spark plugs, wires, and atleast cap/rotor (maybe a whole new dizzy, being thats where the CPS is). That and make sure the ground is hooked up on the engine.
Old Jan 7, 2007 | 11:01 AM
dc5_integra's Avatar
Default Re: Throwing Codes (95 integra)
Could be any of the three things. Fuel, spark, compression. Could be your #1 injector plugged or seized up. Could be a fouled spark plug or a broken wire or a bad distributor. Or it could be something to do with compression like a burnt valve or something along those lines. Try a compression check. Good luck
Old Jan 7, 2007 | 11:02 AM
Default Re: Throwing Codes (dc5_integra)
HIghly doubt that it is the cps
pityocamptes
12
Dec 14, 2011 09:48 AM
Hookeduphatch
Apr 24, 2009 05:37 PM
underb00steg6
Apr 1, 2009 11:13 AM
crxfreak1117
Nov 22, 2007 02:40 PM
95greenteg
May 20, 2006 08:41 PM
