Throwing code 53 and 14. need help.
Old May 25, 2007 | 03:23 PM
b20acura's Avatar
Default Throwing code 53 and 14. need help.
Today I checked my car and it threw: crankshaft speed fluctuation sensor, and electronic air control.
My question is what am I suppose to do to try to see what is wrong and why it is throwing those codes.
Any help would be appreciated.
Motor is jdm b20b.
EDIT: title says 53 but i meant 54
Modified by b20acura at 7:35 PM 5/25/2007
Modified by b20acura at 7:47 PM 5/25/2007
Old May 25, 2007 | 03:25 PM
b20acura's Avatar
Default Re: Throwing code 53 and 14. need help. (b20acura)
P.S. I already searched. Didn't find any post where someone actually fixes the problem.
Old May 25, 2007 | 04:55 PM
turbo93da's Avatar
you need to stat year make model and mods detailed and when the problem occured
Old May 25, 2007 | 06:37 PM
b20acura's Avatar
Default Re: Throwing code 53 and 14. need help. (turbo93da)
this is a 1999 jdm b20b with approx 60k miles on it. i thought about checking for codes because my idle has been wierd lately. every time i am at a stop or come to a stop my idle drops very low, but slowly works its way back up to 700. and if i just tap on the gas itll drop very low and do the same.
Old May 25, 2007 | 08:50 PM
turbo93da's Avatar
you need to check connections at cranksensor connector is located behind above the alternator you might want to consider start running obd1
kickinneon
Jun 16, 2011 09:31 AM
jdmasfuk
16
Feb 19, 2010 07:29 PM
thisandee
Feb 1, 2009 11:27 AM
ay_dawg
Sep 20, 2006 01:56 PM
beedoublejay
Aug 21, 2005 03:28 PM
