Throttle Pulley
Old Mar 23, 2003 | 08:15 AM
hi mom's Avatar
Default Throttle Pulley
My dad was trying to tell me that most Hondas and Acura's have a huge gap between the responce of the pedal..
Is there an aftermarket pulley you can by that shortens the responce? I think he said there was, but I dont know who makes it!
Old Mar 23, 2003 | 11:06 AM
ULTRA911's Avatar
Default Re: Throttle Pulley (95Solo1Tegra)
Tightening the throttle cable decreases the 'gap' between the stepping on the pedal & reaction the time of the opening of the TB. i tighten mines, and my crx jumps at the chance of revving the motor after a slight touch of the pedal. to also help the 'gap' time, getting a light, non-stiff throttle spring to accompany the throttle pulley should give a very sensitive throttle feel.
i know weaponR sells throttle pulley. maybe str, but i'm not sure.
Old Mar 23, 2003 | 11:21 AM
p1ccoloz's Avatar
Default Re: Throttle Pulley (ULTRA911)
you think you can tighten mine a bit? i'm in socal
Old Mar 23, 2003 | 12:58 PM
hi mom's Avatar
Alright cool, thanks for the reply!
Old Mar 23, 2003 | 01:29 PM
intekragsr's Avatar
Default Re: Throttle Pulley (p1ccoloz)
tightening that crap is almost as easy as changing a lightbulb.
All you need is a 12 mm wrench, loosen the bolt, and tighted the other bolt.
Old Mar 23, 2003 | 09:06 PM
p1ccoloz's Avatar
Default Re: Throttle Pulley (intekragsr)
its it much an imporvemt to go through the work?
Old Mar 23, 2003 | 09:12 PM
iH8RICERZ's Avatar
look to see where your throttle pulley is at.......see the cable attatched to it? Thats your throttle cable. Follow it until you see two nuts i believe.....adjust those nuts to tighten or loosen the lag in the throttle response of the peddle
Old Mar 23, 2003 | 09:28 PM
p1ccoloz's Avatar
Default Re: Throttle Pulley (iH8RICERZ)
does this make the car any quicker and what not?
Old Mar 24, 2003 | 08:16 AM
p1ccoloz's Avatar
bump
Old Mar 24, 2003 | 08:21 AM
One Bad GeeSeeR's Avatar
it doesnt make the car quicker, it just makes the car respond faster as you say. soo theres no lag when you stomp on the gas pedal. the reason why they put the lag so granny drivers wont hit the car in front of them if happen to stomp the gas pedal by accident.
Carlo
ricertypeR
Jun 24, 2008 08:44 PM
Kr4nG
Feb 28, 2008 01:22 PM
cleanEG
Jun 23, 2003 05:56 AM
hi mom
Apr 10, 2003 06:33 AM
VTEC-DA
Dec 10, 2002 05:25 PM
