throttle cable for crv vtech
Old Oct 28, 2003 | 07:57 AM
jdm7's Avatar
Default throttle cable for crv vtech
iam doing a crv vtech on my 95 gsr can i use the my stock throttle cable or do i need a ls
Old Oct 28, 2003 | 08:16 AM
arw321's Avatar
Default Re: throttle cable for crv vtech (jdm7)
"VTEC"
Old Oct 28, 2003 | 11:27 AM
JimBlake's Avatar
I think you use what matches the throttlebody. GSR intake manifold puts the throttlebody down lower, so if you're using that, then use the GSR cable. If you can make it reach, as long as it turns the throttle drum, you're OK.
Old Oct 30, 2003 | 09:17 AM
IN VTEC's Avatar
Use whatever throttle cable goes with the throttle body (more specifically the pulley you choose to use).
The GS-R cable and pulley route from the passenger-side. Every other B-series and D-series (I think) throttle bodies route from the driver-side.
The GS-R also has a shorter length from the stay to the pulley.
If you've already got a GS-R TB and cable, keep it simple and just reuse them.
highliner82
Dec 1, 2010 05:35 PM
123Four
Sep 12, 2007 03:08 PM
JDMorgan
Feb 28, 2004 01:20 PM
hondaitegra
Apr 20, 2003 01:20 PM
