Are these compatible?
Old Dec 19, 2005 | 10:05 AM
Ls InTeGrA RaCeR's Avatar
Default Are these compatible?
I want to make sure Im not an idiot but would a head from a 93 Ls work fine on a 99 Ls Block? Would I have any side effects? Thanks.
Old Dec 19, 2005 | 10:12 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Are these compatible? (Ls InTeGrA RaCeR)
well its a obd0, 94-95 is obd1, 96+ is obd2
The newer years have a more aggressive cam, hence the 10hp increase.
Im sure someone can elaborate on this.
Old Dec 19, 2005 | 02:35 PM
Default Re: Are these compatible? (00IntegrAllmotoR)
yeah I know about the the cam thing a little but I need more info.
Old Dec 19, 2005 | 02:48 PM
magicksdc2's Avatar
well the quick answer is, no, you wouldnt have any negative side effects. any nonvtec b series head can be put on any nonvtec b series block.
a question for you would be: what year car is this going into and what do you have to work with as far as wiring harnesses? you'll have to find out which obd you're going to be working with and make sure you've got the right ECU and harness to make it work.
Old Dec 19, 2005 | 03:20 PM
Default Re: (mgx98 ssbp gsr)
I'm not talking about the complete head. I'm only talking about the head and internals (valves, cams, etc...)
Old Dec 20, 2005 | 05:19 PM
Default Re: (Ls InTeGrA RaCeR)
up for more thought.
Old Dec 20, 2005 | 05:33 PM
Deluzional's Avatar
Im sure it would bolt up fine...but the only thing you need to worry about is relocating your PVC valve
Old Dec 20, 2005 | 05:34 PM
95TegSE's Avatar
I'm pretty sure all you'll need is the correct OBD distributor and injectors and you're good to go. I'm not sure how the PCV system works on the OBDIIs though.
Old Dec 21, 2005 | 01:41 AM
Default Re: (95TegSE)
why would I need a different distributer?
travis-b16a2-eg
Aug 12, 2007 11:02 AM
Carbonciv
Jul 12, 2006 10:58 PM
DetroitPOScivic
Jun 17, 2004 11:39 AM
envious1320
Oct 1, 2003 04:20 PM
Ignitecivic
Jun 11, 2003 08:56 AM
