Tesp/high flow cat Q's
Old 12-13-2014, 08:54 AM
Hawaiianhonda's Avatar
Default Tesp/high flow cat Q's
Hey everyone. My prev owner on my 95 gsr has done an amazing job and ruining the exhaust and for some dumb reason, the far flange on the cat has been cut off and welded to the rest of the exhaust so instead of getting another weld on I exhaust, I want to replace the cat for a cheap test pipe jus so Rican a flange back but since its a 95, would it throw a code? Should i get an extender for the 02 on the cat? I jus don't want a code
Old 12-13-2014, 10:24 AM
B_Swapped93's Avatar
Default Re: Tesp/high flow cat Q's
what? you're obd1 you just have the one o2 in the exhaust manifold...you can run a test pipe all day just make sure the primary o2 is plugged in.
Old 12-14-2014, 08:53 PM
I have an idea, is it possible to get an Ls cat and Ls cat back from my gsr header back? She's a 95 gsr coupe BTW.
Old 12-14-2014, 08:58 PM
you could that would be the best thing to do. that way you're not braking any laws etc.
10seconds
12-11-2006 03:32 AM
littlegreenb18
02-24-2006 01:19 PM
lowlight
02-02-2005 08:35 PM
T--Rex
07-31-2004 02:05 PM
swarsing
12-09-2002 03:11 AM
Quick Reply: Tesp/high flow cat Q's
