Temperature Gauge
Old Oct 29, 2007 | 08:49 PM
TonyRomo's Avatar
Default Temperature Gauge
My temp gauge sits a little higher than my friends jdm swapped gsr engine. Sometimes it actually goes lower than its usual spot, especially after I floor it. Anything to be concerned about?
Thanks
Old Oct 29, 2007 | 09:28 PM
DC2 INTEGRA00's Avatar
Default Re: Temperature Gauge (TonyRomo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TonyRomo &raquo;</TD></TR><TR><TD CLASS="quote">My temp gauge sits a little higher than my friends jdm swapped gsr engine. Sometimes it actually goes lower than its usual spot, especially after I floor it. Anything to be concerned about?
Thanks</TD></TR></TABLE>
check ur radiator cap first of all then go from there
Old Oct 29, 2007 | 10:32 PM
TonyRomo's Avatar
Default Re: Temperature Gauge (DC2 INTEGRA00)
cap is on fine, what could this be?
Old Oct 29, 2007 | 11:52 PM
Dunc's Avatar
BCICAN
It could be a lot of things. I wouldn't base your gauge being in the correct place off of another car's gauge. The stock gauges are basically "idiot guides" and serve no real purpose until it's too late.
1.) Does the needle go above the half way mark? If it does, then yes you have an issue.
2.) Is the needle approximately 3/4 of the way up to the half way mark? If so, then you should be fine.
3.) Does the needle move up to the half way mark and then settle back down? If so, you have an issue.
4.) Let the car sit over night (like several hours at least) and then pull the cap off. Is the fluid up the top? If so it's unlikely you have you problem. If not then you might have an issue.
Old Oct 30, 2007 | 12:18 AM
TonyRomo's Avatar
Default Re: Temperature Gauge (Dunc)
It seems like the needle fluxuates from right in front of the half way mark and a tiny bit lower, usually right in front of it.(assuming half way is where the temp icon thing goes up). I just checked the fluid tho and it is fine.
Thanks for your replies
NAmodified
Apr 3, 2007 02:08 PM
Boofster
Dec 6, 2004 03:18 PM
TurboJesse
Sep 25, 2003 04:15 AM
Defiant1999
Jan 5, 2002 07:10 AM
