temperature change and why???
Old Jan 9, 2008 | 08:16 PM
mynameizstitch's Avatar
Default temperature change and why???
ok my girlfriend got a 1998 integra LS and recently i've notice that when she drives the car around town the temperature would be at normal temperature which is about the 1/3 way on the gauge but then when she drives on the freeway the temperature goes almost all the way down to the cold. what may be causing this issue? her car does have an engine check light but then its only indicating a cylinder misfire and this check engine light has been on for a little over half a year now with the temperature being normal all the time. so this temperature changing is just recent so what can be the problem?
Old Jan 9, 2008 | 09:06 PM
andrew714's Avatar
Default Re: temperature change and why??? (mynameizstitch)
change your thermostat, thank me later.
Old Jan 9, 2008 | 11:36 PM
typeR#0427's Avatar
Default Re: temperature change and why??? (andrew714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew714 &raquo;</TD></TR><TR><TD CLASS="quote">change your thermostat, thank me later.</TD></TR></TABLE>
what he said, but just replace it, $20.00 for the thermostat and seal.
Old Jan 10, 2008 | 04:49 AM
lmike6453's Avatar
make sure you put the notch at the 12 o clock position
Old Jan 10, 2008 | 05:26 AM
ok cool thanks everyone
jeped0
Aug 4, 2008 05:45 PM
gary201147
Jul 9, 2007 02:04 PM
leekor12
May 4, 2007 12:14 PM
lax1089
Feb 3, 2007 02:17 PM
junior40er
Nov 4, 2006 12:53 AM
