Temp Issue
Old Mar 20, 2006 | 04:05 AM
Civicracer17's Avatar
Default Temp Issue
Ok I just got back from a Cold A$$ trip to Maine about 6 hours.... NOw When I'm driving the Temp gauge will go from C to Half way then Back to C again it did it the whole trip.... Plus I got now Heat.. I had a Blanket wrapped around me the whole damn time
Old Mar 20, 2006 | 04:12 AM
eluam's Avatar
Default Re: Temp Issue (Civicracer17)
Mine does the same thing. Except I keep my heat when it happens.
Old Mar 20, 2006 | 04:15 AM
Default Re: Temp Issue (geeZus)
Also why AC doesnt work at all.... If I push in the AC button the Light doesnt come on
Old Mar 20, 2006 | 07:10 AM
bump
Old Mar 20, 2006 | 10:31 AM
Vero's Avatar
is it just the light? or do you not feel any cold air blowing? could be a a light out.
as for the temp gauge, first thing I thought of was connections to gauge/meter or thermostat possibly?
Old Mar 20, 2006 | 10:42 AM
jdmotorsports's Avatar
Default Re: Temp Issue (Vero)
well, if your getting no heat and the temp gauge is going nutty then your themostat might be stuck open. how many miles on the car? how old is the coolant?
Old Mar 20, 2006 | 12:13 PM
ejmatzell's Avatar
Default Re: Temp Issue (jdmotorsports)
haha, im in maine right now... i just posted this SAME thing like 2 days ago... my heat works, but after driving 14 hours from virginia, my engine started reading that it was cold... anyway, everyone just told me its the thermostat.
Old Mar 20, 2006 | 12:57 PM
DC2 Mang's Avatar
Default Re: Temp Issue (ejmatzell)
it probably is a thermostat related problem, but integras are known for running on the cold side
Old Mar 20, 2006 | 01:20 PM
CRR 2's Avatar
same thing happened to me replaced thermostat problem was solved
Old Mar 20, 2006 | 01:29 PM
Kicklow's Avatar
Default Re: (CRR 2)
if you cant get a new thermostat right away....i know its ghetto, but zip tie from cardboard or plexiglass in front of your bumper...it will deflect the direct of cold air allowing you to run warmer
Old Mar 20, 2006 | 03:41 PM
Default Re: (Kicklow)
It blows Cold Air all the time... If the car is sitting it will get up to Temp but cold Air blows.. There is 144000 miles on dont know how old the Coolant is
Old Mar 20, 2006 | 05:02 PM
Vero's Avatar
Default Re: (Civicracer17)
so if it is always blowing cold air, you cant yet rule out A/C not working.
I think the hot air issue needs to be addressed before the A/C issue right now.
Old Mar 20, 2006 | 05:09 PM
Default Re: (Vero)
replace the thermostat, and do a coolant flush/fill.
Old Mar 20, 2006 | 06:59 PM
Default Re: (jdmotorsports)
How do I get all the Coolant out of my car? I know the drain plug but will that drain everything?
Old Mar 20, 2006 | 07:50 PM
the drain plug at the bottom of the radiator and the plug on the block.
Old Mar 21, 2006 | 12:47 PM
ok changed the Thermo and Did a Flush.... The Air is a Alittle warmer but not like it should....what is next guys
Old Mar 21, 2006 | 01:26 PM
IntegraJdmb18c1's Avatar
replace the thermosostate and coolant also and bout your ac it might be cause of the ambient temp up at maine wont allow the condensor and orfic tube to cycle and turn state of the freon also since the air is so dense already the ac wont do nething
Old Mar 21, 2006 | 01:29 PM
Vero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicracer17 &raquo;</TD></TR><TR><TD CLASS="quote">ok changed the Thermo and Did a Flush.... The Air is a Alittle warmer but not like it should....what is next guys</TD></TR></TABLE>
how long did it run for? sometimes it can take a while to warm up. Um, make sure no air in the coolant.
Old Mar 21, 2006 | 02:53 PM
Default Re: (Vero)
I bleed the coolant but I'll do it again tomorrow I have driven the car for 30 minutes and the car gets up to temp now but no hot air...plus I'm in Ct now
Old Mar 21, 2006 | 03:13 PM
Sam92Teg's Avatar
When you operate the controls for hot or cold, there is a corresponding valve that is actuated near the firewall. This valve lets the hot coolant (oxymoron) into the heater core which will allow the air to be heated. I would check this valve and or the controls or linkage that operate it.
Kalen13
Honda CR-V & Element
Jan 18, 2018 11:04 AM
agb22
17
Mar 7, 2017 07:11 AM
the soL that could
Mar 14, 2009 06:20 PM
boarding2008
Feb 1, 2009 04:00 PM
-BlueGSR-
Dec 16, 2002 10:35 PM
