temp guage and overheating
Old Oct 14, 2005 | 09:27 AM
parker14us2000's Avatar
Default temp guage and overheating
hey guys, i need to know how high your temp guage is supposed to be after an hour or two of driving mostly uphill. Mine is riding really close top the halfway mark kinda like 11.5 o'clock if u look on a clock. is this ok?. sometimes after i get home my coolant resovoir is full and the coolant is boiling. It goes back to normal in the morning. What could be the problem.
Old Oct 14, 2005 | 12:01 PM
92db2's Avatar
Default Re: temp guage and overheating (parker14us2000)
check your thermostat.
Old Oct 15, 2005 | 07:03 PM
blu3g's Avatar
Default Re: temp guage and overheating (92db2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92db2 &raquo;</TD></TR><TR><TD CLASS="quote">check your thermostat. </TD></TR></TABLE>
Old Oct 17, 2005 | 12:18 PM
previous owners took out the thermostat. i live in the Caribean. Do I really need it?
Old Oct 17, 2005 | 12:26 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (parker14us2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parker14us2000 &raquo;</TD></TR><TR><TD CLASS="quote">previous owners took out the thermostat. i live in the Caribean. Do I really need it?</TD></TR></TABLE>
You don't absolutely need it, but you won't get heat that's that hot. That is probably the reason your temp gauge reads a little higher after prolongs periods of load. Since the thermostat isn't there, the water/coolant is constantly being cycled through the hot engine. It doesn't have enough "time" to cool off in your radiator.
There aren't too many disadvantages to not having a thermostat:
1. Car takes longer to warm up (few people think that you will use more fuel that way because of the FITV/IACV/etc). But you do live in the Carribean.
2. Heat won't be as hot.
3. After car gets hotter, the fans might stay on continuously.
EDIT: I'm not sure how a car with no thermostat would fare sitting in traffic for a while. Others might have to chime in here and give some info there.
Old Oct 17, 2005 | 12:57 PM
95lstegman's Avatar
Default Re: (shamoo)
if you want a lower-temp thermostat, just hollow out your stock one. as in, remove the moving inner part. that way you keep the outer part as a restrictor to make sure the coolant/water doesn't move too quickly through the radiator. don't just get rid of it entirely.
JDM-EJ1
May 16, 2005 08:07 AM
fridexter
Nov 20, 2004 02:52 PM
gelok
Apr 5, 2004 10:19 PM
allmotor.net
Apr 24, 2003 02:58 AM
