temp...
Old May 3, 2007 | 12:23 PM
94xGSRxINTEGRA's Avatar
Default temp...
my car has a cai and some dc headers and wen i dont ride my car hard the temp goes about under the half line and wen i do ride it hard it stays on the colder side...is this normal and if it is, is it fine?
Old May 3, 2007 | 12:28 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: temp... (94xGSRxINTEGRA)
I think its the extra header you have on there, maybe you should try taking one off... how many do you have on there anyways?
Old May 3, 2007 | 12:30 PM
Default Re: temp... (St Jimmy)
o no i didnt mean more than one headers. my bad.. i only have 1 DC header
Old May 7, 2007 | 10:46 AM
pHAck You's Avatar
u from carson?? gsr huh? ill see you around.
Old May 7, 2007 | 12:59 PM
1uncleanDA's Avatar
Default Re: temp... (310speedstars)
its fine
Old May 7, 2007 | 01:16 PM
numbnuts22715's Avatar
it's always been like that.
Our car's temp gauge only goes up about 1/3 of the way, so it's always on the colder half, unless omething is wrong with your car :-/, then it will go to the hotter side.
Old May 7, 2007 | 07:12 PM
Sam92Teg's Avatar
A thermostat is really cheap to replace and could be the reason your temps are showing so much variation. Make sure your fans are operating properly also. And make sure your coolant level is between the max and min lines on your resevoir.
BJIntegra
Jan 17, 2010 01:33 PM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
No
Feb 2, 2006 04:25 PM
bumthology
11
Dec 11, 2004 11:23 AM
EFing8
14
Nov 15, 2002 09:21 PM
