TEIN basic or H&R/Koni setup
Old May 10, 2003 | 10:39 AM
crooked muffler's Avatar
Default TEIN basic or H&R/Koni setup
should i get TEIN basic about 750 plus shipping, i have aset of H&R race springs in my room or should i just get Koni yellows for about 500...
the car is a 92 GSR
Old May 10, 2003 | 10:43 AM
eXstasy's Avatar
Default Re: TEIN basic or H&R/Koni setup (anti-ricecake)
if you want to be able to adjust the level of dampening of the shock, then get the konis. the only advantage the TEIN basic setup would have an over your h&r spring / koni shock combo would be that it has a large range of ride height adjustability, and offers a small amount of spring rate adjustability. although konis will give you the option of changing the spring perch, which adjusts the height very slightly... do a search if you need more info
Old May 10, 2003 | 10:51 AM
Audio28's Avatar
Default Re: TEIN basic or H&R/Koni setup (eXstasy)
i would get koni yellows w/ ground control coil overs. that would have the dampening and height adjustibility. And that would still cost you less the teins.
Old May 10, 2003 | 12:24 PM
mr.beeks's Avatar
Default Re: TEIN basic or H&R/Koni setup (Audio28)
please do yourself a favor
stop playing that mix and match game
it will get you nowhere and end up beign unsatisfied
so go the a real suspension
like tein
or H&R
Old May 10, 2003 | 01:19 PM
intekragsr's Avatar
Default Re: TEIN basic or H&R/Koni setup (FRANCISCO FLORES)
I dont see how anyone could be unsatisfied with koni yellows and a good spring.
Spending a lot of extra cash for Teins is :
1. bling bling jdm importers cost
2. the name
3. integrated threads for height adustability, you wont notice much difference in performace with integraged threads or threaded sleeves.
4. the helper spring on the tiens(not basic) for a woman like ride.
5. hype
Get koni yellows with ground control coilovers. tein is too much hype.
Old May 10, 2003 | 05:46 PM
Default Re: TEIN basic or H&R/Koni setup (intekragsr)
where is the cheapest place to get koni yellows?
im prolly gonna put them together with my H&Rs
Old May 10, 2003 | 10:02 PM
pope's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anti-ricecake &raquo;</TD></TR><TR><TD CLASS="quote">where is the cheapest place to get koni yellows?
im prolly gonna put them together with my H&Rs</TD></TR></TABLE>
my planned setup
Old May 11, 2003 | 06:43 AM
Rory Breaker's Avatar
Default Re: TEIN basic or H&R/Koni setup (pope)
If Im spending $800 on a GC/Koni setup, Ill spend $850 and get Tein SS or H&R, Neuspeed, etc.
Why? Full coilovers were designed to be full coilovers. The springs were engineered with the shocks and vice versa. I would take Tein personally, as I prefer their spring rates and the quality of the product they produce.
Old May 11, 2003 | 10:05 AM
R.S.'s Avatar
Default Re: TEIN basic or H&R/Koni setup (newgsrdriver)
I would also take da Tien SS over the otha ones
Modified by JDM R at 7:44 PM 5/19/2003
Old May 11, 2003 | 10:24 AM
dre000's Avatar
Default Re: TEIN basic or H&R/Koni setup (JDM R)
I just installed tein basics on my car yesterday and I love them. I was in the same position, I was riding on h&r on stock shocks and rather than spending 500 something on some koni yellows I opted to spend 200 more to get some full coilovers.
Old May 11, 2003 | 02:27 PM
B18BGuy's Avatar
Default Re: TEIN basic or H&R/Koni setup (dre000)
The tein super street kit has 16 levels of dampening for about $950.
Old May 11, 2003 | 02:33 PM
WiggiE's Avatar
New User
Default Re: TEIN basic or H&R/Koni setup (B18BGuy)
If those two suspension setups you listed are your only choices, then I would say H&R and Konis. The Tein Basics aren't anything special. Tein is mostly known for their ride quality, although their high end stuff is good.
whited
Suspension & Brakes
15
Aug 1, 2014 10:53 AM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
Yougod
Mar 3, 2006 08:47 AM
p-p-porkchop
Suspension & Brakes
18
Feb 13, 2006 12:30 PM
0ptimus prime
16
Oct 3, 2003 08:09 AM
