Technical Help rough idle white smoke
HELP PLEASE Technical Help rough idle white smoke
its a b20 motor low milage with an ls tranny
ok i changed the tranny oil
changed the oil
spark plugs
drove it and seemed fine
after about 10 min it bogged like it wanted to die. i drove it home turned it off
and when i tried to restart it it wouldnt. i changed the whole distributor and got it
to start but it idles bad and if i put my hand by the muffler i can feel the air and its white and smells like gas.
any help would be greatly appreciated thanks
update: i got home checked everything turned the car on it has a rough idle and if i put my hand by the muffler it wets it and it smells like gas really really strong and help please.
Modified by drastikchangez at 5:27 AM 2/17/2005
changed the oil
spark plugs
Re: HELP PLEASE Technical Help rough idle white smoke (drastikchangez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drastikchangez »</TD></TR><TR><TD CLASS="quote">compression
180
180
162
165
yes i changed the whole distributor, cap and rotor</TD></TR></TABLE>
you have an ls? the compession isnt that bad, but also isnt that good. How much smoke is coming outta the tail pipe? or where is the smoke coming from?
looks like a possible small damage on the headgasket towards 3 and 4, but not bad, how's your coolant, oil?
180
180
162
165
could be a head gasket,, or bad rings on ure 3rd and 4th pistons. about the bad idle im not sure.. hmm
i just read the smells like gas part. after driving alittle does it still idle crappy at a stop?
Re: HELP PLEASE Technical Help rough idle white smoke (VTEC Visions)
ok the car is still idling pretty rough and i noticed gas coming from the
exhaust manifold. i looked at the injectors and noticed one was staying on
which i think that might be the problem if anyone has any other suggestions
let me know thanks.
let me know thanks.
