tailights problem stya on
Old Apr 2, 2006 | 12:15 AM
6doorsentra's Avatar
Default tailights problem stya on
i own a 95 integra. the tailights just started to stay on and i can't turn them off. when i press the brakes it doesn't light up brighter. dont know where to begin to look. Any ideas? thanks!
Old Apr 2, 2006 | 07:07 AM
blkb18's Avatar
Default Re: tailights problem stya on (6doorsentra)
does the switch feel normal? Try tapping on it. Also check the relay, it may be stuck on.
Old Apr 2, 2006 | 08:14 AM
CleanLikeJdm's Avatar
Hype-R Stalker
You didn't put the wrong bulbs in right?
Old Apr 2, 2006 | 08:47 AM
iBrandon's Avatar
Default Re: tailights problem stya on (FlatBlackTeg)
what do u mean just stay on???? like stay on without the headlights turn on??? if so...theres sumthing wrong with ur electrical wiring...you should check that out...plus the bulb u need to use is double filliment for the main one that stays on and brightns up when braked...if u have them in there...one of the filments prolli went out...and need replacing
Old Apr 2, 2006 | 09:03 AM
projectTeG's Avatar
check your brake light switch, the little rubber stopper might have fell out or broke, or the switch might be bad.
Old Apr 9, 2006 | 07:41 PM
the little rubber piece that helps push the button in had broke off... i got it fixed. My bulbs are correct. The lights just stay on whether the lights were on or off...Problem solved. Thankyou
TeggyTitan831
Nov 16, 2018 05:27 PM
BrayzieEF9
20
Feb 8, 2010 06:08 PM
ogawa_jiei
Sep 23, 2006 06:10 PM
MugenHonda
May 30, 2005 08:29 AM
92siracer
May 24, 2004 10:44 AM
