tailights issues...
Old Sep 19, 2003 | 11:08 AM
fast4w$'s Avatar
Default tailights issues...
Ok guys....
I've replaced the left taillamp on a 98 integra because there was water inside. Things were fine for a while and now for some reason both lights seem to be holding lots of water. There has been no damage to the rear end of this car and i just dont get how this much water is collecting in the lights. I've check the gaskets on both and alignment of everything. Is there an issue with this situation from the factory? I've had a similar incident replacing a customers taillamp before for water. I also noticed when you pop off the little cover in the trunk for lamp access, the light are very open and i can see how lots of water can get in...any help is greatly appreciated....
Old Sep 19, 2003 | 11:16 AM
thaiphob's Avatar
Nikon!!!
Default Re: tailights issues... (FaS4wS)
are the bulbs screwed in tight? did you check the seals on the light housing?
Old Sep 20, 2003 | 12:37 PM
fast4w$'s Avatar
Default Re: tailights issues... (thaiphob)
QUOTE=thaiphob]are the bulbs screwed in tight? did you check the seals on the light housing?[/QUOTE]
yes, i've checked everything, i'm not sure what the deal is...thanks for the ideas...[
Old Sep 20, 2003 | 01:35 PM
timmy8151's Avatar
Change your gaskets and seal it up with silicone. I believe ragejed sells thicker gaskets.
Old Sep 20, 2003 | 01:36 PM
n0 iNTegRiTY's Avatar
If you're getting condensation in your tailights, just bake them in the oven, (just to heat up the sealant) and then re-seal them with some clear silicon where it is needed.
Hope this helps you
Old Sep 20, 2003 | 02:19 PM
fast4w$'s Avatar
Default Re: tailights issues... (n0 iNTegRiTY)
Thanks guys...
liyan1430
Honda S2000
Apr 21, 2012 02:34 PM
2k.civic.si
Dec 17, 2010 06:55 AM
Alan-em2
Honda Civic (2001 - 2005)
10
Jun 26, 2009 09:19 AM
92hatch420
Jan 14, 2006 07:34 AM
byronl
Sep 5, 2005 07:36 PM
